    Match Face Orientation
    8 Posts 3 Posters 8.7k Views 3 Watching
    • Onyxx1606O
      Onyxx1606
      Here is a simple yet invaluablefeature. the feature to match orientation from one face to another.
      -heres the pitch:
      --ever been making an object at an obscure angle before? later down the line you decided to add alittle nic-nac or do-dad to it? so you make the additional item and group/component it then it hits you! 83°Z, 159°Y? or was it 38°Z, 195°Y? its be nice to click a single button in the rotation tool on one face and then another to match the face orientation instantly. this would be amazing and extremely helpful.
      Sketchup 2016, Autodesk's; Maya, Mudbox, Motionbuilder, 3DS Max, Sketchbook
        You could just make the "nic nac" a component and give it gluing attributes. Then you wouldn't have to do anything to get it oriented on the angled face correctly.
        • Onyxx1606O
          Onyxx1606
          Oh cool! thanks for the tip!
          you actually helped me summarize this abit better. could it be possible to quick key that feature to the "rotation" tool. ive been using Trimble for around 4 years between Autodesk and im always finding features that are amazing to use, but just difficult to come across organically.
          so id imagine quick keying the 'Glug" function to a single key on the 'rotation' tool, would make things even the easier right?
          like the new 'down arrow' new feature in 2016?
            Or maybe just learn how to add the gluing attribute to the components when you make them?
            • Onyxx1606O
              Onyxx1606
              Yes, i just believe it would be quite more fluid to be able to enable/disable the feature with a single keystroke instead of navigating through a menu. the point im trying to make is:
              its not about "Knowledge" of a particular medium or UI
              its about "Efficiency"
              -making a useful feature even the more ready to use than it already is.
              the feature is there, indeed, i just believe it would be nice to have it at the tip of your finger when needed. it appeals to the type of Users and Creators who navigate through UIs via 'Hotkeys" in opposition to menus [me being one of them]. That's all i suggest =]
              • pbacotP
                Put it in the "wishlist". Or I wonder if a plugin can expedite the process you want. There are many plugins that put components on surface in one way or another--but maybe not how you want.
                You can't simplify the making of a gluing component much, because it needs the input to know the orientation and location of axes. But once the component(s) are made, you can use Unglue and the plugin "Reglue" and hotkeys for those where you need to.
                • Onyxx1606O
                  Onyxx1606
                  Well i know my way around Sketchup, but i dont know anything about the creation of the software and the complications that are involved in improving/adding features to it. so ill try out your suggestion and sing its praises if it works.
                  but again, the idea simply stemed from a minor inconvenience [at most] i encounter every now and then with sketchup and id assumed it was a nice thing for ,not just me bust a few more people, to have if i could have been implemented natively in sketchup.
                  but if it cant so be it, thanks for your input and ill try it asap
                  • pbacotP
                    I am not speaking of writing software. Just common sense. You have to make specific input for the computer to know what you want, is all I mean. The system to make a gluing component describes what plane is used in the component and how it can align to any other plane in the model. Otherwise how would the computer know what you want?
                    But as I said there are plugins that do place components on faces and might provide an idea for some shortcuts. I just don't happen to be able to dig those up at the moment.
