    Moving a Line or Edge
    3 Posts 3 Posters 758 Views 3 Watching
    • medeekM Offline
      medeek
      I am trying to move an edge of a solid after I have push pulled it into shape and added an extra line, however the Transform! method does not seem to work:
                          h_pt1 = [xvalue, @Hx1, @Hy1]
      			h_pt2 = [xvalue, @Hx2, @Hy2]
      			h_pt3 = [xvalue, @Hx3, @Hy3]
      			h_pt4 = [xvalue, @Hx4, @Hy4]
      			h_pt5 = [xvalue, @Hx5, @Hy5]
      			h_pt6 = [xvalue, @Hx6, @Hy6]
      			h_pt7 = [xvalue, @Hx7, @Hy7]
      			group3 = @truss_component2.entities.add_group
      			entities3 = group3.entities
      			group3.description = "Hip Rafter"
      			group3.name = "Hip Rafter"
      			new_face3 = entities3.add_face h_pt1, h_pt2, h_pt3, h_pt4, h_pt5, h_pt6, h_pt7
      			new_face3.pushpull plydepth
      			midline = xvalue + @Ply*0.5
      			lp1 = [midline, @Hx5, @Hy5]
      			lp2 = [midline, @Hx6, @Hy6]
      			linebottom = entities3.add_line lp1, lp2
      			# Translates to vertex of fascia
      			lb_trans = Geom::Transformation.new([0, -@Plyhalf, 0])
       			linebottom.transform! lb_trans
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • sdmitchS Offline
        sdmitch
        An Edge is an entity and can not be transformed by .transform! use .transform_entities instead.
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        vue = mod.active_view
        lb_trans = Geom;;Transformation.new([0, -@Plyhalf, 0])
        #linebottom.transform! lb_trans
        entities3.transform_entities(lb_trans,linebottom)
        http://sdmitch.blogspot.com/
        • TIGT Online
          As Sam says, transformations only apply to containers like component-instances, groups and images.
          A Point3d does not have a transformation, BUT you can use point.transform!(transformation) it relocate it.
          Basic entity objects - like vertices, edges and faces - have to be transformed using:
          objects_parent_entities.transform_entities(a_transformation, [array_of_objects])
          this works with any kind of transformation; or for a vector based 'translation':
          objects_parent_entities.transform_by_vectors([array_of_objects], [array_of_vectors])
          note that each object in the first array must have a matching vector in the second array...
          Also if you are using the these to move say vertices, don't also include some edges or faces which use those vertices - otherwise the vector transformation will be done twice, with unexpected consequences...
