Moving a Line or Edge
I am trying to move an edge of a solid after I have push pulled it into shape and added an extra line, however the Transform! method does not seem to work:
h_pt1 = [xvalue, @Hx1, @Hy1] h_pt2 = [xvalue, @Hx2, @Hy2] h_pt3 = [xvalue, @Hx3, @Hy3] h_pt4 = [xvalue, @Hx4, @Hy4] h_pt5 = [xvalue, @Hx5, @Hy5] h_pt6 = [xvalue, @Hx6, @Hy6] h_pt7 = [xvalue, @Hx7, @Hy7] group3 = @truss_component2.entities.add_group entities3 = group3.entities group3.description = "Hip Rafter" group3.name = "Hip Rafter" new_face3 = entities3.add_face h_pt1, h_pt2, h_pt3, h_pt4, h_pt5, h_pt6, h_pt7 new_face3.pushpull plydepth midline = xvalue + @Ply*0.5 lp1 = [midline, @Hx5, @Hy5] lp2 = [midline, @Hx6, @Hy6] linebottom = entities3.add_line lp1, lp2 # Translates to vertex of fascia lb_trans = Geom::Transformation.new([0, -@Plyhalf, 0]) linebottom.transform! lb_trans -
An Edge is an entity and can not be transformed by .transform! use .transform_entities instead.
mod = Sketchup.active_model ent = mod.active_entities sel = mod.selection vue = mod.active_view h_pt1 = [xvalue, @Hx1, @Hy1] h_pt2 = [xvalue, @Hx2, @Hy2] h_pt3 = [xvalue, @Hx3, @Hy3] h_pt4 = [xvalue, @Hx4, @Hy4] h_pt5 = [xvalue, @Hx5, @Hy5] h_pt6 = [xvalue, @Hx6, @Hy6] h_pt7 = [xvalue, @Hx7, @Hy7] group3 = @truss_component2.entities.add_group entities3 = group3.entities group3.description = "Hip Rafter" group3.name = "Hip Rafter" new_face3 = entities3.add_face h_pt1, h_pt2, h_pt3, h_pt4, h_pt5, h_pt6, h_pt7 new_face3.pushpull plydepth midline = xvalue + @Ply*0.5 lp1 = [midline, @Hx5, @Hy5] lp2 = [midline, @Hx6, @Hy6] linebottom = entities3.add_line lp1, lp2 # Translates to vertex of fascia lb_trans = Geom;;Transformation.new([0, -@Plyhalf, 0]) #linebottom.transform! lb_trans entities3.transform_entities(lb_trans,linebottom) -
As Sam says, transformations only apply to containers like component-instances, groups and images.
A Point3d does not have a transformation, BUT you can usepoint.transform!(transformation)it relocate it.Basic entity objects - like vertices, edges and faces - have to be transformed using:
objects_parent_entities.transform_entities(a_transformation, [array_of_objects])
this works with any kind of transformation; or for a vector based 'translation':
objects_parent_entities.transform_by_vectors([array_of_objects], [array_of_vectors])
note that each object in the first array must have a matching vector in the second array...
Also if you are using the these to move say vertices, don't also include some edges or faces which use those vertices - otherwise the vector transformation will be done twice, with unexpected consequences...
