    2D export, smooth lines missing
    6 Posts 4 Posters 1.3k Views 4 Watching
    • F Offline
      frankleng
      When i export a model into dwg/dxf in SU2005, smooth lines (including round corner) are missing. While, when export to 3D dwg, it's right. See example.
      • ontaottoO Offline
        ontaotto
        Hello there, that happens because is in smooth function, if you select the model and choose the smooth edges tool then you'll realise that lines can back to your model, just play with parameters until you can obtain your "look" desired.
        See the following samples:
        http://mastersketchup.com/wp-content/uploads/2012/11/softsmooth.jpg
        http://photos1.blogger.com/img/m-1b5c5ea16e8df04d991262c067acf99cdd891b1b.jpg
        Twitter: @ontaotto
        • F Offline
          frankleng
          thanks. good hint.
          double click model, chose soft/smooth, change value to 0, all lines will be shown.
          • john2J Offline
            john2
            I am facing a similar problem. However, my object is has much simpler geometry than the ones discussed above
              Turn on Profiles in the Styles Edit tab. Set the weight to 1.
              Profiles Off
              Profiles on and set to 1
              • john2J Offline
                john2
                Thanks for this tip! I'll surely try it πŸ˜„
