    Numeric Input for Positioning?
    3 Posts 3 Posters 519 Views 3 Watching
    • M
      markewi
      Hello, does anyone know if there is an extension where one can quickly edit the xyz position of objects in sketchup? For example, sometimes i need to quickly ground objects to z=0 or to a certain height z=20. The Extension DropGC is pretty good, but limited to grounding objects. Would be super cool if there would be a transformation box with length and weight and a point of origin. Is there something? The Measurement box isn't too handy...
      • mitcorbM
        mitcorb
        Hi.
        Look at this article. Move command
        https://help.sketchup.com/de/article/3000090
        use <x,y,z> in measurement box
          You're right. At least if you don't learn how to use it. Read the Help article mitcorb linked to. If you want to move entities to a specific location relative to the origin, use [x,y,z]. If you want to move things to the ground plane, you can use [,,0]. What ever point you grab with the Move tool will be located at the ground plane.
