    4k menus
    2 Posts 2 Posters 333 Views 2 Watching
    • C
      cadmunkey
      Hi guys,
      I have a 4k monitor and some plugin menus dont resize in their boxes to take advantage of the extra screen estate. An example would be BST tools.
      There is a list of steel beams, but you still have to use a scroll bar despite me being able to drag the menu all the way to the bottom of the screen which would easily enable the steel beam list to appear in its entirety.
      Is there anyway to make this happen? An option I've missed maybe?
      Cheers!
      • S
        slbaumgartner
        That is most likely a result of the way the author of the plugin programmed the HTML for the web dialog, not a SketchUp issue per-se. It is possible to set things up in HTML so that a web page refuses to resize its contents.
