    Dwg to sketch up
    10 Posts 5 Posters 1.4k Views 5 Watching
    • P
      Poot
      Hi guys,
      I'm trying to put an dwg file into sketch up.
      I know that's not really hard, you go file--import----then choose the dwg file.
      But then i get this i putted a photo straight from autocad and one just after importing into sketch up. I suposse that there went something wrong whit the dwg file. But its looks fine i think.
      Please some solutions!
      Thanks in advance
      • K
        kaas
        I think you have to change your units in the import options to match the units in autocad
        • mitcorbM
          mitcorb
          Hi:
          It is difficult to tell from the illustrations, but it appears as if some of your vectors may not be on the z= zero ground plane? Maybe post some other views?
          • J
            Jim
            Thomas did a nice write-up on the topic:
            http://www.thomthom.net/thoughts/2012/12/sketchup-dwg-import-guide/
            • P
              Poot
              I will take a look tomorrow i fixed already whit a little movement off the things.
              Thanks for the fast and good reply's.
              Btw: Is it possible to import the drawing from autocad exactly the same in sketch up,
              whit the colors and name's and everything that would be a less confusing now i have this.
              Everything is put on layers but still it's sometimes confusing.
              Thanks in advance,
              Sam
              • K
                kaas
                You could set up the layer colors in SketchUp the same as in Autocad and set the SketchUp color style to <color by layer> to have it resemble your autocad screen a bit more.
                • P
                  Poot
                  hi guys,
                  I have the same problem whit a new dwg file its very frustrating are there solutions?
                  I already red this article (http://www.thomthom.net/thoughts/2012/1 ... ort-guide/) but i don't have autocad and i'm not planning to buy it. i think its not possible that there is no simple solution for this?
                  Thanks in advance,
                  Sam
                  Dwg file is also attached.
                  kolkstraatBA v2015.dwg
                  • K
                    kaas
                    Whats the problem? It's fairly easy to move those elements in the same Z position as the rest?
                    • D
                      driven
                      that's one busy dxf...
                      34mb skp file after importing with FreeDXF...
                      with color by layer after import...
                      john
                      • P
                        Poot
                        Found a great tutorial/solution to fix this problem.
                        http://getmethod.com/blog/2010/8/24/sketchup-quicktips-flatten-crappy-cad-drawings.html
