    [REQ] Save all .skps in folder to earlier version
    7 Posts 4 Posters 1.3k Views 4 Watching
      Anyway to convert all models in a folder to v8 if they are saved as v12 aka 2016
      • K
        kaas
        This works for me on Win7X64. Just copy-paste in your ruby console
        It first asks for the source directory, next it will ask for the target directory. And then it converts all sketchup files and saves a copy to the target location.
        USE AT YOUR OWN RISK - USE A COPY OF YOUR SOURCE DIRECTORY
        source_path = UI.select_directory(title; "Select Source V16 directory")
        target_path = UI.select_directory(title; "Select Target V8 directory")
        folder_list=Dir.entries(source_path)
        folder_list.to_a.each{|file|
          if file.include? ".skp"
            source = File.join(source_path, file)
            status = Sketchup.open_file source
            model = Sketchup.active_model
            target = File.join(target_path, file)
            status = model.save_copy(target, Sketchup;;Model;;VERSION_8)
        edit: no clue why indents aren't visible
        [mod=:221mh31f]use 'code' for formatting - use 'ruby' for single lines etc
        TIG[/mod:221mh31f]
        • pbacotP
          Might work for Mac?
          Also
          Any way to set file (or SU globally) to always save as v.8 (older version).
          Any way to know by looking at a file what version it is (without opening) on Mac?
            Thanks Kaas. Worked a treat.
            • D
              driven
              @pbacot said:
              Might work for Mac?
              yes, but...
              it would be better to add a filter for those that are already v8...
              Also
              yes, but...
              not as easy as the first, and not on autosaves or backups...
              you'll loose a lot of the new functionality written into later version skp files...
              and you'll get a warning every time you reopen them [unless suppressed]...
              easier to use v8 if you always want v8...
              Not in 'Finder' unless you Tag all the skps using 'Automator' or 'Applescript'
              I did do a mac 'save as version' plugin when this method first came out, but there was little interest...
              john
              • pbacotP
                I have a colleague who hasn't updated. I don't find I get any warnings when I open up a v8 file or anything that I use that affects the usefulness of the file. If I write "v8" in the name, it's meaningless--I always want to check if I saved the right version, when checking files on the server. It's probably not worth any extra headaches though, if there's no simple way. He'll update soon.
                • K
                  kaas
                  Maybe try this plugin and bind it to the save keypress?
                  http://sketchucation.com/forums/viewtopic.php?t=33441
