    Sketchup 2016 rotate
    7 Posts 7 Posters 1.2k Views 7 Watching
      Macker
      Hey guys,
      It seems to me the new inferencing system on 2016 has kind of ruined the previous functionality of the rotate tool, unless I am doing something wrong. It's a bit tricky to explain...
      Imagine you have a line drawn at an arbitrary angle and wish to rotate it to the red axis. Previously all you would do is select the line, select a rotation origin and a reference point, then move the reference point to align with the red axis. Done.
      The new inferencing system appears to rotate the protractor/compass of the rotate tool to "zero" on the line that you are using as your reference angle/point, throwing out the ability to snap to the red axis.
      I must be doing something wrong, surely?
      Check out my blog @ http://macviz.blogspot.co.uk
      • BoxB Offline
        It has changed. One tip, try the down arrow.
          I don't see any changes to the old behavior. Only the addition of the cursor keys to lock the orientation of the rotation axis.
          • cottyC Offline
            cotty
            I can't reproduce this problem too, maybe you can create a screencast to show us the problem?
            my SketchUp gallery
            • JasonWDJ Offline
              JasonWD
              Same here. I just tried that new inference thing and it's fantastic!
              SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
                djo
                Hey Macker... I was freaking out too... and then I got it... To do your "old way" you need to use the down arrow instead of shift. So now there is two ways of doing it. Great feature.
                • oceanembersO Offline
                  oceanembers
                  Yeah shift now locks orientation AND plane, down locks orientation only
