    Sketchy FFD on 2016
    17 Posts 8 Posters 5.8k Views 8 Watching
    • utilerU
      utiler
      Does anyone know if Sketchy FFD work on 2016? I've tried loading it and can't get it to work.
      I'm wanting to deform a sphere; FFC would be the best way to do that, yeah?
      Just Curious...
      • BoxB
        What do you want to do to the sphere?
        Do you have an image?
        Edit:
        Haven't used it for years, never took to it.
        But loaded and working in 2016 as far as I can see.
        • A
          abhininja
          i am not able to use ffd in 2016
          its showing this
            Patch FFD has nothing to do with your volume!
            (except the fact that you access to the Context Menu! 😄
            It's a creation of a Grid Surface at the origine! 🤓
            So FFD is working very fine inside 2016!
              And works fine also inside 2017! 😎
              A cool trick is using native Structure palette for Select the FFD box! 🤓
              and Right Click / Modify FFD Group! (always over the Structure Palette)
              • gillesG
                gilles
                Just double click…
                  Just Double Click
                  Yes for paradisiacal scene! ☀ Like one volume like above! 😄
                  ...but when you a bunch of objects overlaping on the scene, it's a mess to find the right one! 💚
                  J'ai déjà vécu ce cauchemar! 😄
                  Chat échaudé craint l'eau froide! 💚
                  PS even for the example above when you make a "double click" you don't know visually
                  if you have enlighted the volume or the FFD volume! 💚
                  You must Double click on a Point but not so evident!
                  It's so easy on the structure Palett! ☀
                  And you make a Double Click less! 🤓
                  • gillesG
                    gilles
                    I mean in Structure…
                      OK ...so we are agree Structure is very practical!
                      One time for call FFD
                      One time for edit it!
                      • A
                        abhininja
                        thanx pilou, but i am not able to control volume,its showing only 'patch FFD dimention'
                        see,i have only 3 option, if i am clicking on 'make patch' opening Patch FFD Dimention , how can i control volume. please help me!!!
                        • TIGT
                          Do you have Guides set to be visible ? [View menu]
                          If not, then you'll see nothing to edit.
                          To edit the points edit the group of FFD guides, as @Pilou showed you earlier, you can easily select it and edit it from the Outliner list...
                            Sorry Structure in French = Outliner ! 😉
                            PS For see all the FFD Menu you must have selected a Group! 🤓
                            (and not a Group of Groups : in this case you will see Menu but not effective on all groups)
                            So explode all and make an unic Group!
                            Don't work with a Component! 🤓
                            • A
                              abhininja
                              thanx guys
                              • D
                                dcalanya
                                I am using a lot of plugin.
                                I downloaded this plugin and installed it. But I couldn't see it to use??
                                is this plugin only for PRO version?
                                I am using Sketchup 2016 Make
                                • TIGT
                                  It works in all versions.
                                  Its menu items show up in the right-click context-menu, but only IF a suitable group is selected...
                                    Use the Outliner for an easy selection of FFD groups created!
                                    • E
                                      ezzmagic
                                      I have a problem that was working and after a period of stop work .. Is it a solution to this problem?
