    How to Use datalist in sketchup webdialog box
    6 Posts 4 Posters 3.3k Views 4 Watching
    • R
      rnpatel9789
      Hello Everyone,
           I just want to use HTML datalist inside the sketchup webdialog box window if anyone have any idea how to use it please help me.
      • K
        kaas
        More (visual) info is needed I think. What kind of datalist? What should it look like in the webdialog? What kind of actions must a user be able to do? etc etc.
        • sdmitchS
          sdmitch
          @rnpatel9789 said:
          Hello Everyone,
          Perhaps something like this
          dataarray = ['a', 'b', 'c', 'd']; datalist = ""
          dataarray.each{ |d|
          	datalist += "<option value='"+d+"' >"+d+"</option>"
          dlg = UI;;WebDialog.new("Dummy", false,"dummy",200,200,10,10,true)
          html = <<-HTML
          <body>
           Selection;<select id='list'>#{datalist}</select><br><br>
          </body>
          HTML
          dlg.set_html(html)
          dlg.show
          http://sdmitch.blogspot.com/
          • R
            rnpatel9789
            hi sdmitch,
            I doing something like what you posted but not with selection rather with input field to add behaviour something like autofill in search box. I am using a specific HTML file for the webdialog window and using javascript function to fill the data into the datalist. But In my case it seems the ".inner_html" in not working. I don't know what is the reason may sketchup is not supporting or something else.
            Here's code sample:
            In javascript:
            function setData(projectnos, roomnames){
            proj_no = projectnos.split(",");
            var options = '';
            for(var i = 0; i < proj_no.length; i++)
            options += '<option value="'+proj_no[i]+'" />';
            document.getElementById('proj').innerHTML = options;
            In HTML:
            <input type="text" name="ProjectNumber" list="proj" />
            <datalist id="proj">
            <option value="001"/>
            </datalist>
            If you have some solution for this then please help me it's very helpful for me.
            Thank you
            • K
              kaas
              Your html & javacript code is not valid.
              The for-loops should have beginning and closing brackets.
              The options have a value but no content.
              Look for the complete syntax here:
              http://www.w3schools.com/js/js_loop_for.asp
              http://www.w3schools.com/tags/tag_option.asp
              • D
                driven
                innerHTML gives you the tags, as well as text content, that you probably don't want...
                            <script>
                                    function showNew(key,val) {
                                    (key).textContent=(val).value;
                                    </script>
                john
