How to Use datalist in sketchup webdialog box
Hello Everyone,
I just want to use HTML datalist inside the sketchup webdialog box window if anyone have any idea how to use it please help me. -
More (visual) info is needed I think. What kind of datalist? What should it look like in the webdialog? What kind of actions must a user be able to do? etc etc.
@rnpatel9789 said:
Hello Everyone,
I just want to use HTML datalist inside the sketchup webdialog box window if anyone have any idea how to use it please help me.Perhaps something like this
dataarray = ['a', 'b', 'c', 'd']; datalist = "" dataarray.each{ |d| datalist += "<option value='"+d+"' >"+d+"</option>" } dlg = UI;;WebDialog.new("Dummy", false,"dummy",200,200,10,10,true) html = <<-HTML <body> Selection;<select id='list'>#{datalist}</select><br><br> </body> HTML dlg.set_html(html) dlg.show -
hi sdmitch,
I doing something like what you posted but not with selection rather with input field to add behaviour something like autofill in search box. I am using a specific HTML file for the webdialog window and using javascript function to fill the data into the datalist. But In my case it seems the ".inner_html" in not working. I don't know what is the reason may sketchup is not supporting or something else.
Here's code sample:
In javascript:
function setData(projectnos, roomnames){
proj_no = projectnos.split(",");
var options = '';
for(var i = 0; i < proj_no.length; i++)
options += '<option value="'+proj_no[i]+'" />';
document.getElementById('proj').innerHTML = options;
}In HTML:
<input type="text" name="ProjectNumber" list="proj" />
<datalist id="proj">
<option value="001"/>
</datalist>If you have some solution for this then please help me it's very helpful for me.
Thank you
Your html & javacript code is not valid.
The for-loops should have beginning and closing brackets.
The options have a value but no content.Look for the complete syntax here:
http://www.w3schools.com/js/js_loop_for.asp
http://www.w3schools.com/tags/tag_option.asp -
innerHTML gives you the tags, as well as text content, that you probably don't want...
<script> function showNew(key,val) { (key).textContent=(val).value; } </script>john
