    Help me build a fast pc for vray sketchup
    renderpluginsextensions
    12 Posts 3 Posters 4.1k Views 3 Watching
      sketchuh
      I currently use MacBook Pro :
      2.7ghz Intel core i7
      16gb 1600mhz ddr3
      Nvidia GeForce gt 650m/ Intel had graphics 4000
      And I have an iMac 27 retina for network rendering.
      But I want a faster computer. My budget is minimum usd$4000 for the custom built.
      I heard I should get Titan graphics card? Basically I have no clue what I should get
      For my custom built pc.
      I think I need a at least a processor 4 times faster than 2.7 ghz i7;
      I am not sure vray sketchup uses fast graphic card.
      I don't want to invest in expensive graphic card and not improve render time!
      Thanks in advance.
      From a clueless power vray sketchup user.
      • K Offline
        kokoriko17
        Intel® Core™ i7-5960X
        32GB RAM DDR4 2133
        Samsung PCIe SSD ( 512GB is OK )
        Vray doesn't use GPU unless using RT CUDA ( for this get Nvidia GTX 980 Ti - Titan X isn't worth the negligible performace )
        CPU + RAM + SSD + GTX price all together around $2450
        Add another $150 for a powersupply + Chasis
        Connect it to your iMac screen using minidisplay adapter or get any 30" screen. ( i'm using my iMac and it's great for rendering - mine is Core i7 3.9 + SSD + 32GB RAM + GTX780m )
          sketchuh
          wow thanks for the suggestion. my company's budget could be higher though.
          1. will Nvidia GTX 980 Ti render faster than using Intel® Core™ i7-5960X? but this will give me some reference.
          • K Offline
            kokoriko17
            Actually for rendering in VRAY you only use the CPU unless you're using VRAY RT which will be set to CUDA. It's when things get interesting, you can preview whatever you're working on really quickly with such a capable card.
            Normally GPUs are much faster than CPUs when it comes to processing power. Not that they are more powerful but they have limited instruction sets. That's why they're used over CPUs when it comes to bruteforcing and cracking keys etc...
              sketchuh
              maybe in Vray Sketchup 3.0, we will be able to use GPU render and it will be 10 times faster than cpu...haha...
              • andybotA Offline
                andybot
                Seems the best thing for vray currently is adding as many cpu cores as possible. With a big budget, I'd suggest getting a dual cpu motherboard (Supermicro makes most of them) and putting two Xeon E5 chips (like the 2680 v3, 12 core) on there. Graphics card doesn't matter for vray currently, and it may be a while before it is up to the same level as cpu render. If you do get a high end graphics card, better stick with nvidia Titans.
                Andy
                • K Offline
                  kokoriko17
                  Andy
                  Titan is a waste of money. GTX 980 Ti offers the same performance for half the price.
                  • andybotA Offline
                    andybot
                    You're right, you can get good value from the high-end nvidia cards. Main thing is CUDA seems to be what most render engines use, OpenCL is not getting much support these days (I found that out the hard way 😞 )
                    • K Offline
                      kokoriko17
                      Another reason why I didn't go for the new Macs as they dumped Nvidia and got back to ATI ( dumb move I must say )
                        sketchuh
                        Thanks Andybot and kokoriko17 for the further help!!
                        I am hopeful that I will get a ideal rig for my pc built.
                          sketchuh
                          Can I have a dual 6 core i7 cpus set up and i think that will be a cheaper config.
                          I am not sure if dual i7 cpu possible. but it works. it will definitely be faster than a 8 core i7
                          Does Vray sketchup support dual i7 cpus???
                          • andybotA Offline
                            andybot
                            no, you need server CPU (Xeon) for dual cpu motherboard.
