    Reset/zero transformation, scale and rotation
    7 Posts 6 Posters 4.5k Views 6 Watching
    • PixeroP Offline
      Pixero
      Is there a plugin to reset the transformation, scale and rotation of a component?
      • JQLJ Offline
        JQL
        Right click menu?
        Reset Scale and Reset Skew.
        Rotation is harder but if you use the move tool without selecting the component you find the red dot dongles and you can rotate to 0.
        www.casca.pt
        Visit us on facebook!
        • sdmitchS Offline
          sdmitch
          Maybe this
          unless file_loaded?((__FILE__))
          	UI.add_context_menu_handler do |menu|
          		sel = Sketchup.active_model.selection
          		if sel.first.is_a? Sketchup;;ComponentInstance
          			menu.add_separator
          			menu.add_item('Reset Scale Rotation') {
          				mod = Sketchup.active_model
          				ent = mod.entities
          				mod.start_operation 'Reset Scale Rotation'
          				cmp=sel.first;org=cmp.transformation.origin
          				t=cmp.transformation.to_a
          				t[0]=1;t[1]=0;t[2]=0;#t[3]=nil
          				t[4]=0;t[5]=1;t[6]=0;#t[7]=nil
          				t[8]=0;t[9]=0;t[10]=1;#t[11]=nil
          				t[12]=org.x;t[13]=org.y;t[14]=org.z;#t[15]=nil
          				cmp.transformation=cmp.transformation.set! t
          				mod.commit_operation
          	file_loaded((__FILE__))
          http://sdmitch.blogspot.com/
          • PixeroP Offline
            Pixero
            Thanks, will try this. 👍
              Jim
              Another option would be to set the Transformation to IDENTITY.
              instance.transformation = IDENTITY
              This would also move the instance to the Origin, but it's easy to move it back if that's what you need.
                Alternatively, could you perhaps reset the object's transformation back to the inverse of what it was ?
                obj.transform!(obj.transformation.inverse)
                • G Offline
                  galinette
                  Alternatively, you can delete that component instance, and create a new one with the components window. It will have an identity rotation/scale, just place it on the origin.
