    [Solved] Move along Normal
    24 Posts 6 Posters 2.5k Views 6 Watching
    • deaneauD Offline
      deaneau
      Hello,
      what plugin doing Move Along Normal?
      I have a Building with a lot off windows (glass)
      i would move all selected faces along the normal.
      Dean
      Edit Solved:
      A Ruby Coder have now solved this problem with a plugin. Could be the programer publish this plugin in the next time.
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
      • cottyC Offline
        cotty
        Looks like there are all faces selected?
        my SketchUp gallery
          driven
          select all windows needed, select move, click on the bottom of the perpendicular wall, move along that line, click to end?
          Why do you need a Plugin for that?
          john
          • JQLJ Offline
            JQL
            Move Along is capable of Move Along Normals...
            You can find it in Fredo Tools and it's great!
            www.casca.pt
            Visit us on facebook!
              driven
              do you want to Move them or Thicken them?
              are they all the same material or layer or group?
              i.e. what do they have in common?
              • deaneauD Offline
                deaneau
                isnt so easy.
                i have windows in all directions N/S/W/E
                some other buildings have more than 100 windows in different directions.
                EDIT:
                @JQL could you explane this? i have try move along.
                here in an other 3d program (before and after)
                you can see, if the face is reversed, normal move go to inside
                Snap_2015.10.29_00h48m01s_007_.pngSnap_2015.10.29_00h49m03s_008_.pngSnap_2015.10.29_00h50m02s_009_.png
                • deaneauD Offline
                  deaneau
                  no not really. i must move the faces..for night mesh. the polygons have the same place, so this will flicker. i need a movement for all faces to the outside. less than 1mm
                  Here an result of what i want do.
                  all the windows at night is separated of the main object.
                  and will fade out at the day.
                  http://archiv.trainzdepot.net/forum/attachments/nightmode.jpg
                  • JQLJ Offline
                    JQL
                    Try Fredo Tools wich has a plugin called "move along" check it...
                    Or Joint Push Pull also From Fredo.
                    www.casca.pt
                      driven
                      the reason I ask about commonalty...
                      I have a plugin that finds a material and push/pulls any face that uses it...
                      maybe it could be adapted, but I'd need to see a sample skp with at least a couple of different walls with windows...
                      if you PM me one, I'll have a look, without promise of success or time frame...
                      it may be easy, maybe not...
                      john
                      • deaneauD Offline
                        deaneau
                        JQL i can move the faces together in X+/X- and Y+/Y- ?
                        Tom have had the same problem in the year 2009
                        look here
                        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63305#p579661
                        i dont know the name of the plugin, if Tom have make this.
                        @driven is not important what object you use.
                        you could download on at the 3d warehouse. actually all pullman buildings
                        all faces what will be glass
                        3D Warehouse
                        3D Warehouse is a website of searchable, pre-made 3D models that works seamlessly with SketchUp.
                        (3dwarehouse.sketchup.com)
                        • fredo6F Offline
                          fredo6
                          What Dean is looking for is a multi_comp Move tool with local direction (normal being just a case of this).
                          It could only apply to a selection of several groups and components, because only comps have a local set of axes.
                          So MoveAlong won't do the job and JointPushPull won't do it either, because it operates on faces, not on comps.
                          This would deserve a specific plugin, say MoveLocal.
                          Fredo
                          • JQLJ Offline
                            JQL
                            Are you sure Fredo?
                            www.casca.pt
                            • deaneauD Offline
                              deaneau
                              OK Sketchup is Sketchup and comparing with other 3d software could work.
                              here an inspiration
                              before i can do normal move i must disconnect the polygons from the main object.
                              when i use negative value this work,too.
                              a multi_comp move isnt the right word.
                              all polygons have a normal. could be in sketchup,too.
                              Snap_2015.10.29_14h16m18s_016_.pngSnap_2015.10.29_14h15m27s_015_.pngSnap_2015.10.29_14h15m08s_014_.png
                                driven
                                Dean, I downloaded Pullman+Dispensary.skp
                                changing window materials with ruby
                                once done, you can select by material, make group, add the group to it's own layer and edit as needed...
                                but, I'm not sure I understand your needs...
                                john
                                • deaneauD Offline
                                  deaneau
                                  @driven you have a PM
                                  • fredo6F Offline
                                    fredo6
                                    Indeed, this can be done of faces too, as they have a normal.
                                    The only problem is that when faces are connected, a Move would also extend its neighbour. But this can be overcome by a Copy / erase original.
                                    I thought this could be done with JPP, with the option PushPul and NO-Border, but apparently there is a bug in JPP (it erases adjacent faces).
                                    Fredo
                                    • fredo6F Offline
                                      fredo6
                                      I thought this could be done with JPP, with the option PushPul and NO-Border, but apparently there is a bug in JPP (it erases adjacent faces). Note that it works if you keep the original faces and copy them at the given offset (options Thickening + NO-Border)
                                      Fredo
                                      • HornOxxH Offline
                                        HornOxx
                                        Hi Dean
                                        yes I know, that's not really what you are looking for and I probably embarrass myself
                                        suggesting the following. If you have placed your windows on the walls, perhaps you can use
                                        SkUp´s component's propertys in order to achieve your desired result - at least until there is
                                        the technical solution you are looking for.
                                        By the way, I like the look and feel of your nightly church windows - somehow Christmas like.
                                        never trust a skinny cook
                                          driven
                                          Dean, I've been thinking about your 'problem' rather than your 'sought solution' [moving faces]...
                                          to STOP the flickering caused by having two faces in the same space, just don't have two faces...
                                          only use the original face and change the Material on a toggle...
                                          I made a little script called night_n_day, it toggle the window material from 0.4 to 0.95 opacity...
                                          here's a test on the UNMODIFIED model...
                                          to run I open the model fresh, open Materials and 'eyedrop' on any window, load the script into 'Ruby Console' and type night_n_day to toggle opacity...
                                          it could be set to darken all the bricks, tile, stuco, etc... at the same time, or be trigger by a scene change...
                                          I think moving geometry just over complicates a solution for your stated problem...
                                          but, I've been wrong before...
                                          simple test...
                                          john
                                          • deaneauD Offline
                                            deaneau
                                            ok what i have do?
                                            1. select the windows glass
                                            2. select all with the same material
                                            3. group
                                              4.copy & past in place
                                            now i have two groups with the same place of the parts.
                                            what i need is this like in the attachement
                                            @Fredo you´re right. i must discconnect the polys from the main model before i can move along normal.
                                            @HornOxx hm your idea is only a crompromise. however thank you for your idea.
                                            @driven i the attachement i have explain the result.. the distance i have set to 20cm for a better visualization.
                                            the churches in the picture above have two windows glasses per windows. on for day and one for night.
                                            the day mesh will fade to dark and the night mesh will fade lighter.
                                            this simulate light behind the windows.
                                            Move along Normal.skp
                                            • 1 / 2
