    [Solved] Move along Normal
    24 Posts 6 Posters 2.2k Views 6 Watching
      driven
      do you want to Move them or Thicken them?
      are they all the same material or layer or group?
      i.e. what do they have in common?
      • deaneauD Offline
        deaneau
        isnt so easy.
        i have windows in all directions N/S/W/E
        some other buildings have more than 100 windows in different directions.
        EDIT:
        @JQL could you explane this? i have try move along.
        here in an other 3d program (before and after)
        you can see, if the face is reversed, normal move go to inside
        Snap_2015.10.29_00h48m01s_007_.pngSnap_2015.10.29_00h49m03s_008_.pngSnap_2015.10.29_00h50m02s_009_.png
        • deaneauD Offline
          deaneau
          no not really. i must move the faces..for night mesh. the polygons have the same place, so this will flicker. i need a movement for all faces to the outside. less than 1mm
          Here an result of what i want do.
          all the windows at night is separated of the main object.
          and will fade out at the day.
          http://archiv.trainzdepot.net/forum/attachments/nightmode.jpg
          • JQLJ Offline
            JQL
            Try Fredo Tools wich has a plugin called "move along" check it...
            Or Joint Push Pull also From Fredo.
            www.casca.pt
            Visit us on facebook!
              driven
              the reason I ask about commonalty...
              I have a plugin that finds a material and push/pulls any face that uses it...
              maybe it could be adapted, but I'd need to see a sample skp with at least a couple of different walls with windows...
              if you PM me one, I'll have a look, without promise of success or time frame...
              it may be easy, maybe not...
              • deaneauD Offline
                deaneau
                JQL i can move the faces together in X+/X- and Y+/Y- ?
                Tom have had the same problem in the year 2009
                look here
                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63305#p579661
                i dont know the name of the plugin, if Tom have make this.
                @driven is not important what object you use.
                you could download on at the 3d warehouse. actually all pullman buildings
                all faces what will be glass
                3D Warehouse
                (3dwarehouse.sketchup.com)
                • fredo6F Offline
                  What Dean is looking for is a multi_comp Move tool with local direction (normal being just a case of this).
                  It could only apply to a selection of several groups and components, because only comps have a local set of axes.
                  So MoveAlong won't do the job and JointPushPull won't do it either, because it operates on faces, not on comps.
                  This would deserve a specific plugin, say MoveLocal.
                  • JQLJ Offline
                    JQL
                    Are you sure Fredo?
                    www.casca.pt
                    • deaneauD Offline
                      deaneau
                      OK Sketchup is Sketchup and comparing with other 3d software could work.
                      here an inspiration
                      before i can do normal move i must disconnect the polygons from the main object.
                      when i use negative value this work,too.
                      a multi_comp move isnt the right word.
                      all polygons have a normal. could be in sketchup,too.
                      Snap_2015.10.29_14h16m18s_016_.pngSnap_2015.10.29_14h15m27s_015_.pngSnap_2015.10.29_14h15m08s_014_.png
                        driven
                        Dean, I downloaded Pullman+Dispensary.skp
                        changing window materials with ruby
                        once done, you can select by material, make group, add the group to it's own layer and edit as needed...
                        but, I'm not sure I understand your needs...
                        • deaneauD Offline
                          deaneau
                          @driven you have a PM
                          • fredo6F Offline
                            Indeed, this can be done of faces too, as they have a normal.
                            The only problem is that when faces are connected, a Move would also extend its neighbour. But this can be overcome by a Copy / erase original.
                            I thought this could be done with JPP, with the option PushPul and NO-Border, but apparently there is a bug in JPP (it erases adjacent faces).
                            • fredo6F Offline
                              I thought this could be done with JPP, with the option PushPul and NO-Border, but apparently there is a bug in JPP (it erases adjacent faces). Note that it works if you keep the original faces and copy them at the given offset (options Thickening + NO-Border)
                              • HornOxxH Offline
                                HornOxx
                                Hi Dean
                                yes I know, that's not really what you are looking for and I probably embarrass myself
                                suggesting the following. If you have placed your windows on the walls, perhaps you can use
                                SkUp´s component's propertys in order to achieve your desired result - at least until there is
                                the technical solution you are looking for.
                                By the way, I like the look and feel of your nightly church windows - somehow Christmas like.
                                never trust a skinny cook
                                  driven
                                  Dean, I've been thinking about your 'problem' rather than your 'sought solution' [moving faces]...
                                  to STOP the flickering caused by having two faces in the same space, just don't have two faces...
                                  only use the original face and change the Material on a toggle...
                                  I made a little script called night_n_day, it toggle the window material from 0.4 to 0.95 opacity...
                                  here's a test on the UNMODIFIED model...
                                  to run I open the model fresh, open Materials and 'eyedrop' on any window, load the script into 'Ruby Console' and type night_n_day to toggle opacity...
                                  it could be set to darken all the bricks, tile, stuco, etc... at the same time, or be trigger by a scene change...
                                  I think moving geometry just over complicates a solution for your stated problem...
                                  but, I've been wrong before...
                                  simple test...
                                  • deaneauD Offline
                                    deaneau
                                    ok what i have do?
                                    1. select the windows glass
                                    2. select all with the same material
                                    3. group
                                      4.copy & past in place
                                    now i have two groups with the same place of the parts.
                                    what i need is this like in the attachement
                                    @Fredo you´re right. i must discconnect the polys from the main model before i can move along normal.
                                    @HornOxx hm your idea is only a crompromise. however thank you for your idea.
                                    @driven i the attachement i have explain the result.. the distance i have set to 20cm for a better visualization.
                                    the churches in the picture above have two windows glasses per windows. on for day and one for night.
                                    the day mesh will fade to dark and the night mesh will fade lighter.
                                    this simulate light behind the windows.
                                    Move along Normal.skp
                                      driven
                                      but HOW are you switching them, you have no Layers, only a single Group and the same Material with both?
                                      are you doing that outside of SU after this is done?
                                      • deaneauD Offline
                                        deaneau
                                        @driven
                                        the game switch this.
                                        in sketchup i build the day and night mesh insert this in a game and the game doing this..
                                        this look like the churches
                                          driven
                                          given your current workflow, adding code into frontface can work like this...
                                          I set at 10mm and add a different material for 'select by color' grouping...
                                          would this work for you?
                                          at 10mm blue glass...
                                          • deaneauD Offline
                                            deaneau
                                            hey cool this cold be a solution. question is, is this than a new object group? when not its better the plugin-in generate a new color what i have never had before. so i can choose this new generated polys by material and group this.
                                            in your animation i cant see how it work for frontside polys (white).
