    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    DC - Changing one and all instances update?
    8 Posts 4 Posters 2.8k Views 4 Watching
    • PixeroP Offline
      Pixero
      How do I make so that all component instances update if I change a value in one Dynamic Component?
        Your DCs will all change but only if they are instances of the same dynamic component's definition.
        But if they are instances of a 'unique' definition then they won't - just like a regular Component.
        Placing an instance of a DC might make it unique [creating a sibling definition], but copying it might not [leaving two or more instances of the same DC definition], but you need to experiment...
        • PixeroP Offline
          Pixero
          Hmmm...I can't get it to work.
          So it has nothing to do to the structure of the DC?
          I was thinking of maybe having a component inside a component and opening the first to update all??? πŸ˜•
          Is there any example file to study?
          • P Offline
            pcmoor
            to change all instances of a DC(even different DCs) you use the option dialog on the selection, this will make all their common properties the same.
            It is a good idea to group DCs after using the move,copy so that they don't become unique on a further move
            there is a need for a better attribute sorter, editor which will I hope be included in the next release otherwise there is a real need for a ruby script similar to excels find and replace
            • PixeroP Offline
              Pixero
              So it only works on the selection?
              I was hoping for a way of selecting one instance and the changes would be applied to all instances even if not selected.
              • P Offline
                pcmoor
                Unlike common components which can be scaled, any changes to a copy makes that DC unique. Once the DC has become unique it no longer has a shared definition.
                • JQLJ Offline
                  JQL
                  But you can use Component Browser to replace a selection of components for another component.
                  That replacement will change every component into an instance of the same component.
                  www.casca.pt
                  Visit us on facebook!
                  • PixeroP Offline
                    Pixero
                    I just realised Thomthoms Selection Toys has Select all active DC instances that works with DC's even if they have been scaled or modified. πŸ‘
