    3D Truss Models
    1.5k Posts 31 Posters 924.3k Views 30 Watching
      Look at your Private messages! 😉
      • medeekM Offline
        medeek
        As the number of advanced options have increased (common trusses) the user input menu has slowly grown in size until it is so large that it often does not fit the screen of many laptops and smaller screens.
        This problem has been well documented by a number of users for quite some time.
        This weekend I spent some time putting together a new HTML menu for advanced options for roof trusses:
        http://design.medeek.com/resources/images/truss_su323_800.jpg
        I still need to work out the metric version and also all of the language translations but otherwise I think it is almost ready to roll out.
        As you mouse over each of the options a 320x240 image will display as shown, hopefully clarifying the meaning or usage of each parameter/option.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
          Help Image is a very very good idea! 👍
          Very very first draft as you can see the "?" ! 😉
          Veuillez choisir les options avancées pour les fermes de toiture
          Roof and Wall Sheathing = Revêtement de Toiture et Revêtement Mural
          Roof Sheathing = Revêtement de Toiture
          Roof Sheating Thickness = Épaisseur du Revêtement de Toiture
          Gable Wall Sheathing = Revêtement Mural du Pignon
          sub-fascia = Sous-fascia ?
          sub-fascia type = Type de Sous-fascia ?
          sub-fascia width = Largeur de Sous-fascia ?
          sub-fascia depth = Profondeur de Sous-fascia ?
          rakeboard = ?
          gable overhang = Porte-à-faux du Pignon
          rake board width = Largeur ?
          rake board depth = Profondeur ?
          outloockers = Débords ?
          outlooker spacing = Espacement du Débord ?
          outlooker size = Taille du Débord ?
          structural outlookers = Débord Structurel ?
          outlooker @ roof peak = Débord @ Pointe de Toit ?
          heel blocking = Blocage du Talon ?
          heel block orientation = Orientation du Talon ?
          cladding = Revêtement
          roof cladding = Revêtement de Toiture
          hip and ridge cap = Capuchon de Croupe et de Faîtage ?
          gable wall cladding = Revêtement Mural du Pignon
          additional options = Options Supplémentaires
          soffit cut = Coupe de Soffite ?
          roof returns = Retours de Toit
          roof battens = Lattes de toit
          ceiling gypsum = Gypse de Plafond
          gutters = Gouttières
          dropped top chord = Panne Supérieure Lancée ?
            First glance! 😄 (must be refined)
            Veuillez sélectionner l'un des types de fermes suivants:
            Commun en W - Tunnel - Mono-Pente - Ciseaux - Empennage - Double-Pente
            Corde d'Arc (?) - Arceau de Barrique (?) - Polynésien - Bombé - Cathédrale - Plateau (?)
            Simple Ciseau - Simple Cathédrale - Shed - Voûte En Berceau (?) - Tunnel à la Mansart - Caisson
            Treillis - Cathédrale Symétrique - Studio en Berceau - Double Inversé - Corde Parallèle - Charpente
            Remarque: Les types de ferme Shed, Arceau de barrique, Studio en Berceau et Double Inversé sont en cours de développement et ne sont pas encore disponibles.
            • medeekM Offline
              medeek
              Version 2.1.1 - 12.04.2017
              • Enabled a graphical user interface for advanced options of roof trusses.
              design.medeek.com
                new refinement! 😄
                • Commun ( Classique en w) - Grenier( Habitable) - Mono-Pente - Ciseaux( Entrait Retroussé)- Empennage ( à coyeau) Double-Pente ( Asymétrique)
                • Corde d'Arc (Arc) - Arceau de Barrique (Arc triangulé) - Polynésien ( tropicale)- Bombé ( entrait retroussé variante ou Polonceau ) - Cathédrale - Plateau(Double ferme articulée)
                • Simple Ciseau - Simple Cathédrale - Clergé (Contemporaine ) - Voûte En Berceau (En voute ) - Grenier Surélevé ( à la Mansart)- Caisson ( à entrait décalé)
                • Plat ( poutre treillis )- Cathédrale Symétrique ( treillis à deux pentes) - Studio en Berceau ( à entrait décalé) - Double Inversé ( double articulée) - Corde Parallèle - Charpente
                https://img15.hostingpics.net/pics/255775ferme03.jpg
                https://img15.hostingpics.net/pics/647757ferme02.jpg
                https://img15.hostingpics.net/pics/484019ferme04.jpg
                https://img15.hostingpics.net/pics/576001ferme01.jpg
                • medeekM Offline
                  medeek
                  I am trying to understand how the Mac .plist file works. Is it similar to the registry? I have a client that is having some trouble with registering (inputting their serial into the global settings) and having their system save the serial number.
                  Unfortunately, I don't own a Mac so I am not much help. Does anyone use the plugin on a Mac and have had similar problems with saving the serial number? Where does one go to manually edit the .plist file and enter in the serial number manually.
                  design.medeek.com
                  • G Offline
                    glro
                    not only that
                    i had the same questions
                    so i bought a mac: https://en.wikipedia.org/wiki/Mac_Mini
                    sheap, you can use windows mouse, keyboard and screen
                    there are a few things to modify in the ruby code por windows, to make it work on a mac
                    • medeekM Offline
                      medeek
                      I am working on adding the heel blocking since it is an option listed in the advanced options.
                      http://design.medeek.com/resources/images/truss_su324_800.jpg
                      So far there has not been much call for this feature but a few people have inquired so I figured we might as well add it in for completeness. The red coloration is for clarity in the image above.
                      I will probably add the option to allow for venting holes since this is fairly typical in my neck of the woods.
                      design.medeek.com
                      • pbacotP Offline
                        Very important. Sometimes the heel blocking, when taller, is a truss manufactured square that might have sheathing.
                        • medeekM Offline
                          medeek
                          I agree, I was investigating this a while back but I'm not sure yet what is standard practice, there could be a number of ways of handling this.
                          http://res.cloudinary.com/engineering-com/image/upload/v1484676854/tips/SHEAR_PANELS_ego3xz.jpg
                          http://res.cloudinary.com/engineering-com/image/upload/v1484694321/tips/SHEAR_PANELS2_vis1pr.jpg
                          design.medeek.com
                          • pbacotP Offline
                            Those look nice. I think sometimes the truss blocking has a diagonal which would make it effective (but the engineer will want plywood on it anyway it seems). You can have the truss all the way to the top or the method you show allows (1) continuous plywood gets nailed to the top of the truss block and the solid block provides the shear nailing (2) sometimes decorative rafter tails are added which need to pass through the space above the truss block.
                            • medeekM Offline
                              medeek
                              Featured on the SketchUp Extension Inspection:
                              design.medeek.com
                                Very enlighting video! 😎
                                else (Always : https://trussfr.weebly.com 😉
                                Truss Type = Type de Fermes
                                (not sure to translate all names of this little list of part of trusses)
                                King Post
                                Queen Post
                                Fink
                                Howe
                                Fan
                                Mod Queen
                                Double Fink
                                Double Howe
                                Mod Fan
                                Triple Fink
                                Quad Fink
                                Out-to-Out Span = Portée Hors tout
                                Top Chord Angle = Angle de Corde Supérieure (?)
                                Overhang Left = Porte-à-faux Gauche
                                Overhang Right   (Same as Left) = Porte-à-faux Droit (Identique au Gauche)
                                TC Size = Taille TC (? à définir)
                                BC Size = Taille BC (? à définir)
                                Web Size = Taille (?)
                                Ply Thickness = Epaisseur du Pli
                                Raised Heel (No, Yes) =Talon surélevé (?) ( (Non, Oui)
                                Heel Heigh = Hauteur du Talon (?)
                                Bldg.lenght = Longueur Bâtiment
                                Truss Spacing = Espacement de Ferme
                                Gable End Trusses (Yes, No, Front) = Poutrelles d'extrémité (Oui, Non, Face Avant)
                                Gable Stud Spacing = Espacement Goujons de Pignon (?)
                                Adv. Roof Options (Yes, No) = Options Avancées de Toit (Oui, Non)
                                PS
                                Does the Messages' window data is self-adapting to the length of words ?
                                • medeekM Offline
                                  medeek
                                  Thank-you Pilou, I will add these phrases into the language file.
                                  Yes, the SU menu automatically adjust for the length of the words so even though French is often more verbose than English it does not matter. I've noticed though that Russian has some problems rendering in the SU menus.
                                  I would have liked to see the video dive into the advanced menus more but I realize there is far too much material to cover in such a short video.
                                  design.medeek.com
                                    Excellent! 👍
                                    What is BC and TC size ? 😳
                                    Minor Roof Family = Famille de Toit Secondaire
                                    Gable Dormer = Lucarne de Pignon
                                    Hit Dormer = Lucarne de Toit
                                    Shed Dormer = Lucarne de Hangar
                                    Gable Roof Minor = Pignon de Toit Secondaire (?)
                                    Hip Roof Minor = Lucarne de Toit Secondaire (?)
                                    Dutch Gable Roof Minor = Pignon de Toit Hollandais Secondaire (?)
                                    The (?) does not signify that is forcefully false but can maybe be enhanced! 😉
                                    Else works fine! 😄
                                    • medeekM Offline
                                      medeek
                                      BC = Bottom Chord
                                      TC = Top Chord
                                      Web = Internal (web) members of truss
                                      design.medeek.com
                                        Thx for the Infos! ☀
                                        • medeekM Offline
                                          medeek
                                          The license registration module was causing some problems in isolated cases so I've released a sub-rev. 2.1.1b to address that issue.
                                          If you are trying to enter in your serial number and it does not appear to take, first verify that you are not entering in any leading or trailing white spaces if that does not solve the problem you may be encountering the issue at top, in that case download the latest version which should address the issue fully.
                                          design.medeek.com
                                            Valley set chest => Panel de Noue
                                            Stepdown Hip Set => Panel de Panne de Rive Inclinée
                                            Terminal Hip Set => Panel de Sablière
                                            Northeast Hip Set => Panel de Linçoir
                                            Metal plate connectors = Connecteur Métallique Plat
                                            Gusset = Gousset
                                            Web = Membrure
                                            Web = Fiche & Contre-Fiche
                                            in this following Schema "Chantignole" is false : must be "Arbalétrier" ! 🤓
                                            https://media.ooreka.fr/public/image/plan-charpente-29-big-9926265.jpg
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 74
                                            • 75
                                            • 50 / 75
