    3D Truss Models
    1.5k Posts 31 Posters 978.2k Views 30 Watching
    • medeekM Offline
      medeek
      Version 1.8.3 - 02.12.2017
      • Enabled metal plate connectors, materials and custom layers for Fan trusses.
      • Added energy/raised heels for Fan truss (3 variants: wedge, slider and vertical w/ strut).
      • Roof slope can be toggled between Pitch or Degrees (input) for common trusses in the global settings.
      http://design.medeek.com/resources/images/truss_su193_800.jpg
      Currently the metric template forces the roof slope to degrees however in the imperial templates (inches, feet) the user can select between Pitch or Angle for common truss types. I will need to update all of the truss types with this global setting option.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.8.4 - 02.14.2017
        • Enabled roof cladding for gable and hip rafter roofs.
        • Roof slope can be toggled between Pitch or Degrees (input) for gable and hip rafter roofs in the global settings.
        design.medeek.com
        • medeekM Offline
          medeek
          To create this roof was not an entirely automated process but I'm slowly getting there. The trim tool comes in really handy for creating valley and jack rafters but ultimately it would be nice to auto create L-Shaped, T-Shaped and U-Shaped roofs.
          http://design.medeek.com/resources/images/truss_su194_800.jpg
          View model here:
          3D Warehouse
          3D Warehouse is a website of searchable, pre-made 3D models that works seamlessly with SketchUp.
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • pbacotP Offline
            Impressive work here! Thanks for the update!
            • medeekM Offline
              medeek
              design.medeek.com
              • medeekM Offline
                medeek
                Found a small bug/typo in the latest release in the gable roof cladding, rolled a minor rev. 1.8.4b.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.8.5- 02.18.2017
                  • Enabled roof cladding for dutch gable and TJI rafter roofs.
                  • Added TJI rafter roofs with dual glulam beams.
                  • Added Soffit Cut within Advanced Options for TJI Roof w/ GLB.
                  http://design.medeek.com/resources/images/truss_su195_800.jpg
                  View model here:
                  3D Warehouse
                  First new roof type in added in quite a while. Lately I have been focusing most of my effort on cleaning things up and making sure all the options are working correctly for each roof type and configuration.
                  Soffit cuts with TJI (I-Joist) rafters gets a bit interesting but I've finally implemented it:
                  http://design.medeek.com/resources/images/truss_su196_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    View model here:
                    3D Warehouse
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Same house, just a lookout between the beams:
                      View model here:
                      3D Warehouse
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Trying out the Rayelectron Rendering plugin, I'm fairly impressed.
                        https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/5/b/5b53385b51afc6a965a9a106ad959c19eb7f555f_1_690x425.jpg
                        https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/c/8/c825384639ec908941de0b58d4e0a2d30fabb52d_1_690x425.jpg
                        https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/1/d/1d953c927c2fc220e09683dc1293b5b43c348b94_1_690x425.jpg
                        https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/5/0/50014fb9e46778bb529dd7fbd6a2547d1e4c5aff_1_690x425.jpg
                        View model here:
                        3D Warehouse
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.8.5b - 02.23.2017
                          • Addressed minor bug with "Front Only" gable end scissor trusses.
                          • Addressed minor bug with soffit cuts and TJI rafter roofs with dual glulam beams.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Working on 2 ply and 3 ply headers as well as LSL headers:
                            http://design.medeek.com/resources/images/truss_su197_800.jpg
                            design.medeek.com
                              Have you try this free real time one?
                              SimLab Composer Light : Maxi 1920 * 1080
                              (can load any format of 3D file) πŸ˜‰
                              https://s6.postimg.org/3uxmjbk0h/house4.jpg
                              • medeekM Offline
                                medeek
                                Version 1.8.6 - 02.25.2017
                                • Added 2x sawn lumber and LSL headers for Gable Dormers.
                                • Enabled interior wall sheathing (Gypsum Wall Board) for Gable Dormers.
                                • Enabled ceiling sheathing (Gypsum Wall Board) and ceiling battens for common trusses.
                                http://design.medeek.com/resources/images/truss_su198_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  An example dormer created with the dormer tool and the gable roof created with the common truss tool. Note that I have enabled all of the cladding, sheathing and GWB in the global settings.
                                  http://design.medeek.com/resources/images/truss_su199_800.jpg
                                  View model here:
                                  3D Warehouse
                                  When you select "YES" for the gypsum ceiling in the advanced options of common trusses and additional dialog is presented which then allows for manually adjusting the GWB thickness, ext. wall inset, and ceiling battens (size, spacing).
                                  You will notice that in the global settings within the "Sheathing" tab a couple of new items have been added for Gypsum Sheathing.
                                  Now I just need to enable ceiling sheathing for vaulted truss and rafter roofs, yet another large task added to the todo list.
                                  Attic and Gambrel attic trusses will require not only ceiling GWB but also the attic GWB on walls and flat and sloping ceilings.
                                  With the addition of all the interior and exterior cladding, the plugin can now generate the majority of the structural features of a roof.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    This probably pertains more directly to the Wall Plugin I have been working on but I could also test out the concept with the dormer module.
                                    If the user enables the exterior wall cladding I could also enable a further option which will draw the corner and window trim as shown. This option would only become active if the cladding option is selected. I would create a new tab in the global settings for the all of the trim options (size, material etc...)
                                    I'm also considering a rudimentary door and window module that can auto-fill the window and door holes in the Wall Plugin, however I don't know if architects and designers would find any use for it since they may be inclined to use more sophisticated 3rd party window and door plugins.
                                    The reason I am considering this is that it would further automate the creation process and I have yet to find a window and door plugin that I am 100% satisfied with.
                                    http://design.medeek.com/resources/images/truss_su200_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Raised heel fink truss roof with 1.5"x1.5" ceiling battens and 5/8" GWB at a 5.5" wall inset.
                                      http://design.medeek.com/resources/images/truss_su201_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Scissor truss with ceiling battens and GWB:
                                        http://design.medeek.com/resources/images/truss_su202_800.jpg
                                        I've never actually seen ceiling battens used but I assume they are used in some locales.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/3/d/3d2ee9c9d039f58143a0f5c9f927c21db91c5edf_1_690x422.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Tomorrow is my birthday. Given all of the health issues I've had the last few months I'm just happy to still be kicking. My neck and general constitution is still not quite right but at least I'm functional and for that I am very grateful.
                                            In response to the overwhelming positive vibe I've received from the SketchUp community during my downtime I would like to offer the following offer to current users of the plugin who currently have a non-expired license/serial number:
                                            1.) By March 2, 2017 (offer ends midnight Mar. 2) post on this forum or the other SketchUp forum a screenshot or rendering of a current project you are working on that you have utilized the plugin. Give your company name or state "for personal use". Also describe what features you primarily use within the plugin (ie. trusses, rafters, floors etc...) Please try to make the picture such that it shows the output from the plugin as clearly as possible.
                                            2.) Send me an email with the time and date of your post and your name/company name and I will then extend your license out for another full year from the existing expiration date (add an additional year to your license).
                                            My reason for doing this is primarily to see how you are using the plugin in the real world. Is it making any sort of meaningful impact? Does it actually get used, or do people purchase it out of curiosity and then never actually use it?
                                            I also want to give back a little to those who continue to support the plugin and its development. Hopefully a few of you will take me up on this offer since I am really curious to see how the plugin is actually being used by real architects and designers.
                                            I hope I am not violating any board rules by posting this offer.
                                            design.medeek.com
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 75
                                            • 76
                                            • 33 / 76
