    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      I agree. I will probably spend the next few weeks making sure plates, materials, layers, raised heels, one gable only feature and other issues are resolved for all truss types and rafter roof types.
      After that I would like to finish up the hip sets, timber truss, and flat truss modules.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I'm quite familiar with all of the industry names for various configurations of roof trusses (ie. Fink, Howe, Mod Queen, King Post, Queen Post, Double Fink etc...) What distinguishes these trusses from each other is the configuration of the webs of the truss which is dictated by the number of panels of the top chords and bottom chords. For example the Howe truss is four top chord panels and four bottom chord panels (4/4). Most diagrams show up to a Triple Howe truss (8/8). What is not typically shown is an (8/6) and (8/7) truss, is there any reason for this? These two configurations seem perfectly valid to me, I would call them a Triple Queen and Fan Fink truss respectively. Has anyone come across either of these two configurations?
        design.medeek.com
        • medeekM
          medeek
          Actually I would change the name of the Fan Fink to Double Fan.
          The next size up would be:
          Quad Fan 10/5
          Double Mod Fan 10/6
          Triple Fan 10/7
          Quad Queen 10/8
          Quad Fink 10/9
          Quad Howe 10/10
          As the number of panels increase in the top chord the number of potential variations increases. So for a four panel top chord truss the number of variations is three, the general pattern is:
          (2/x) truss = 1 possible configuration
          (4/x) truss = 3 possible configurations
          (6/x) truss = 4 possible configurations
          (8/x) truss = 5 possible configurations
          (10/x) truss = 6 possible configurations
          (12/x) truss = 7 possible configurations
          design.medeek.com
          • medeekM
            medeek
            My naming convention for the 12/x series of common trusses.
            http://design.medeek.com/resources/images/TRUSS_TYPES_12x.jpg
            Trusses sure are beautiful things.
            design.medeek.com
            • medeekM
              medeek
              The common fan truss now has raised heels, plates, materials and layers:
              http://design.medeek.com/resources/images/truss_su193_800.jpg
              I apologize for the slow progress. I've had some 12 hour work days last week so I didn't have much left in the tank once I got home, usually just eat and then went straight to bed.
              design.medeek.com
              • medeekM
                medeek
                I've been thinking about stub trusses, is there any need for those?
                design.medeek.com
                • medeekM
                  medeek
                  I originally made the roof pitch a drop down box/option since most people use standard roof pitches with their roofs (ie. 4:12, 7:12, 9.5:12 etc...) However, the problem with that is it does not allow one to enter in values other than those provided in the drop down list. The alternative would be to make this a simple text field where the user specifies the roof pitch however my thinking was having the drop down list was more convenient. For the metric templates (when the plugin switches to metric mode) the pitch is given in degrees rather than the customary US pitch (x/12) method, and there is no drop down list, the user just enters in the degrees.
                  I guess what I should do is add an option into the global settings which allows one to toggle between the drop down list or a simple text field for the pitch input, for the imperial units template.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.8.3 - 02.12.2017
                    • Enabled metal plate connectors, materials and custom layers for Fan trusses.
                    • Added energy/raised heels for Fan truss (3 variants: wedge, slider and vertical w/ strut).
                    • Roof slope can be toggled between Pitch or Degrees (input) for common trusses in the global settings.
                    Currently the metric template forces the roof slope to degrees however in the imperial templates (inches, feet) the user can select between Pitch or Angle for common truss types. I will need to update all of the truss types with this global setting option.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.8.4 - 02.14.2017
                      • Enabled roof cladding for gable and hip rafter roofs.
                      • Roof slope can be toggled between Pitch or Degrees (input) for gable and hip rafter roofs in the global settings.
                      design.medeek.com
                      • medeekM
                        medeek
                        To create this roof was not an entirely automated process but I'm slowly getting there. The trim tool comes in really handy for creating valley and jack rafters but ultimately it would be nice to auto create L-Shaped, T-Shaped and U-Shaped roofs.
                        http://design.medeek.com/resources/images/truss_su194_800.jpg
                        View model here:
                        3D Warehouse
                        (3dwarehouse.sketchup.com)
                        design.medeek.com
                        • pbacotP
                          Impressive work here! Thanks for the update!
                          • medeekM
                            medeek
                            design.medeek.com
                            • medeekM
                              medeek
                              Found a small bug/typo in the latest release in the gable roof cladding, rolled a minor rev. 1.8.4b.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.8.5- 02.18.2017
                                • Enabled roof cladding for dutch gable and TJI rafter roofs.
                                • Added TJI rafter roofs with dual glulam beams.
                                • Added Soffit Cut within Advanced Options for TJI Roof w/ GLB.
                                http://design.medeek.com/resources/images/truss_su195_800.jpg
                                View model here:
                                3D Warehouse
                                First new roof type in added in quite a while. Lately I have been focusing most of my effort on cleaning things up and making sure all the options are working correctly for each roof type and configuration.
                                Soffit cuts with TJI (I-Joist) rafters gets a bit interesting but I've finally implemented it:
                                http://design.medeek.com/resources/images/truss_su196_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Same house, just a lookout between the beams:
                                    View model here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Trying out the Rayelectron Rendering plugin, I'm fairly impressed.
                                      https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/5/b/5b53385b51afc6a965a9a106ad959c19eb7f555f_1_690x425.jpg
                                      https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/c/8/c825384639ec908941de0b58d4e0a2d30fabb52d_1_690x425.jpg
                                      https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/1/d/1d953c927c2fc220e09683dc1293b5b43c348b94_1_690x425.jpg
                                      https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/5/0/50014fb9e46778bb529dd7fbd6a2547d1e4c5aff_1_690x425.jpg
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.8.5b - 02.23.2017
                                        • Addressed minor bug with "Front Only" gable end scissor trusses.
                                        • Addressed minor bug with soffit cuts and TJI rafter roofs with dual glulam beams.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Working on 2 ply and 3 ply headers as well as LSL headers:
                                          http://design.medeek.com/resources/images/truss_su197_800.jpg
                                          design.medeek.com
                                            Have you try this free real time one?
                                            SimLab Composer Light : Maxi 1920 * 1080
                                            (can load any format of 3D file) 😉
                                            https://s6.postimg.org/3uxmjbk0h/house4.jpg
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 76
                                            • 77
                                            • 33 / 77
