    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Version 1.8.5- 02.18.2017
      • Enabled roof cladding for dutch gable and TJI rafter roofs.
      • Added TJI rafter roofs with dual glulam beams.
      • Added Soffit Cut within Advanced Options for TJI Roof w/ GLB.
      http://design.medeek.com/resources/images/truss_su195_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      First new roof type in added in quite a while. Lately I have been focusing most of my effort on cleaning things up and making sure all the options are working correctly for each roof type and configuration.
      Soffit cuts with TJI (I-Joist) rafters gets a bit interesting but I've finally implemented it:
      http://design.medeek.com/resources/images/truss_su196_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        View model here:
        3D Warehouse
        design.medeek.com
        • medeekM
          medeek
          Same house, just a lookout between the beams:
          View model here:
          3D Warehouse
          design.medeek.com
          • medeekM
            medeek
            Trying out the Rayelectron Rendering plugin, I'm fairly impressed.
            https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/5/b/5b53385b51afc6a965a9a106ad959c19eb7f555f_1_690x425.jpg
            https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/c/8/c825384639ec908941de0b58d4e0a2d30fabb52d_1_690x425.jpg
            https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/1/d/1d953c927c2fc220e09683dc1293b5b43c348b94_1_690x425.jpg
            https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/5/0/50014fb9e46778bb529dd7fbd6a2547d1e4c5aff_1_690x425.jpg
            View model here:
            3D Warehouse
            design.medeek.com
            • medeekM
              medeek
              Version 1.8.5b - 02.23.2017
              • Addressed minor bug with "Front Only" gable end scissor trusses.
              • Addressed minor bug with soffit cuts and TJI rafter roofs with dual glulam beams.
              design.medeek.com
              • medeekM
                medeek
                Working on 2 ply and 3 ply headers as well as LSL headers:
                http://design.medeek.com/resources/images/truss_su197_800.jpg
                design.medeek.com
                  Have you try this free real time one?
                  SimLab Composer Light : Maxi 1920 * 1080
                  (can load any format of 3D file) πŸ˜‰
                  https://s6.postimg.org/3uxmjbk0h/house4.jpg
                  • medeekM
                    medeek
                    Version 1.8.6 - 02.25.2017
                    • Added 2x sawn lumber and LSL headers for Gable Dormers.
                    • Enabled interior wall sheathing (Gypsum Wall Board) for Gable Dormers.
                    • Enabled ceiling sheathing (Gypsum Wall Board) and ceiling battens for common trusses.
                    http://design.medeek.com/resources/images/truss_su198_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      An example dormer created with the dormer tool and the gable roof created with the common truss tool. Note that I have enabled all of the cladding, sheathing and GWB in the global settings.
                      http://design.medeek.com/resources/images/truss_su199_800.jpg
                      View model here:
                      3D Warehouse
                      When you select "YES" for the gypsum ceiling in the advanced options of common trusses and additional dialog is presented which then allows for manually adjusting the GWB thickness, ext. wall inset, and ceiling battens (size, spacing).
                      You will notice that in the global settings within the "Sheathing" tab a couple of new items have been added for Gypsum Sheathing.
                      Now I just need to enable ceiling sheathing for vaulted truss and rafter roofs, yet another large task added to the todo list.
                      Attic and Gambrel attic trusses will require not only ceiling GWB but also the attic GWB on walls and flat and sloping ceilings.
                      With the addition of all the interior and exterior cladding, the plugin can now generate the majority of the structural features of a roof.
                      design.medeek.com
                      • medeekM
                        medeek
                        This probably pertains more directly to the Wall Plugin I have been working on but I could also test out the concept with the dormer module.
                        If the user enables the exterior wall cladding I could also enable a further option which will draw the corner and window trim as shown. This option would only become active if the cladding option is selected. I would create a new tab in the global settings for the all of the trim options (size, material etc...)
                        I'm also considering a rudimentary door and window module that can auto-fill the window and door holes in the Wall Plugin, however I don't know if architects and designers would find any use for it since they may be inclined to use more sophisticated 3rd party window and door plugins.
                        The reason I am considering this is that it would further automate the creation process and I have yet to find a window and door plugin that I am 100% satisfied with.
                        http://design.medeek.com/resources/images/truss_su200_800.jpg
                        design.medeek.com
                        • medeekM
                          medeek
                          Raised heel fink truss roof with 1.5"x1.5" ceiling battens and 5/8" GWB at a 5.5" wall inset.
                          http://design.medeek.com/resources/images/truss_su201_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Scissor truss with ceiling battens and GWB:
                            http://design.medeek.com/resources/images/truss_su202_800.jpg
                            I've never actually seen ceiling battens used but I assume they are used in some locales.
                            design.medeek.com
                            • medeekM
                              medeek
                              https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/3/d/3d2ee9c9d039f58143a0f5c9f927c21db91c5edf_1_690x422.jpg
                              design.medeek.com
                              • medeekM
                                medeek
                                Tomorrow is my birthday. Given all of the health issues I've had the last few months I'm just happy to still be kicking. My neck and general constitution is still not quite right but at least I'm functional and for that I am very grateful.
                                In response to the overwhelming positive vibe I've received from the SketchUp community during my downtime I would like to offer the following offer to current users of the plugin who currently have a non-expired license/serial number:
                                1.) By March 2, 2017 (offer ends midnight Mar. 2) post on this forum or the other SketchUp forum a screenshot or rendering of a current project you are working on that you have utilized the plugin. Give your company name or state "for personal use". Also describe what features you primarily use within the plugin (ie. trusses, rafters, floors etc...) Please try to make the picture such that it shows the output from the plugin as clearly as possible.
                                2.) Send me an email with the time and date of your post and your name/company name and I will then extend your license out for another full year from the existing expiration date (add an additional year to your license).
                                My reason for doing this is primarily to see how you are using the plugin in the real world. Is it making any sort of meaningful impact? Does it actually get used, or do people purchase it out of curiosity and then never actually use it?
                                I also want to give back a little to those who continue to support the plugin and its development. Hopefully a few of you will take me up on this offer since I am really curious to see how the plugin is actually being used by real architects and designers.
                                I hope I am not violating any board rules by posting this offer.
                                design.medeek.com
                                  Happy Birthday! 😎
                                  • facerF
                                    facer
                                    Midgard - Three Level House
                                    Sketch Plan (SK) Study of Floor - Roof Truss Options
                                    Using "Medeek plugin" to quickly access Floor - Truss Options
                                    Excellent addition to the "toolbox" of plugins
                                    Ray Facer Architect
                                    Melbourne Australia
                                    01Floor Truss Options - using Medeek Truss 02
                                    • pbacotP
                                      Fine example of use in unusual construction
                                      • jujuJ
                                        juju
                                        Happy CAKE DAY! nom nom nom πŸŽ‰
                                        Here you go, WIP model for standard details...
                                        Julian Smith, Professional Senior Architectural Technologist. Primary use of Medeek Truss plugin is the expedited creation of roof construction (trusses, rafters, etc.).
                                        • medeekM
                                          medeek
                                          Thank-you for the examples posted. I appreciate the continued support of the development of this plugin. I only wish I had more time to devote to it but my current job has me occupied most of the week and weekends can be tough with competing interests.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            I've been giving some though to the soffit and fascia and I realized that in many cases the design may call for a closed soffit:
                                            http://design.medeek.com/resources/images/truss_su205_800.jpg
                                            I've seen soffits constructed with plywood and also metal (aluminum, vented).
                                            Also the fascia I am creating currently should be more properly labeled the sub-fascia since in many cases the true fascia board is a thinner 5/4 or 1x material. If metal is used then the sub-fascia is covered over with a fascia cover:
                                            [img]
                                            http://www.arteroofing.com/include/get.php?nodeid=98[/img]
                                            design.medeek.com
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 76
                                            • 77
                                            • 33 / 77
