    Pivot and rotational points
    5 Posts 4 Posters 791 Views 4 Watching
    • JP2009J Offline
      JP2009
      I am trying to make a custom ride that will be animated in a game and need help in creating pivot and rotational points.
      This is the pivot point (red arrow) the bar has to pivot upward by 90 degrees like a lever.
      http://i1188.photobucket.com/albums/z416/abletudu/Sketchup Ride Projects/Restraint pivot_zpsbqc5ldiw.jpg
      This is the rotaional point (red arrow) the center hub is stationary and the vertical arm rotates:
      http://i1188.photobucket.com/albums/z416/abletudu/Sketchup Ride Projects/Rotational point_zpsnpombfa2.jpg
      How would I achieve setting the points?
      • N Offline
        numerobis
        make a component and then right click > change axes
        • JP2009J Offline
          JP2009
          Could you please elaborate more on this?
          • Wo3DanW Offline
            Wo3Dan
            @jp2009 said:
            ........ and need help in creating pivot and rotational points.
            Maybe attached file will help. It involves rotating a group or component about one of its bounding box's axes by applying the 'Move' tool. groups and components have four grips per side.
            influencing the size of bounding box of component for rotations
            • BoxB Offline
              I posted a rotational rig component here some time back.
              http://sketchucation.com/forums/viewtopic.php?t=58124%26amp;p=529167#p529167
