    Environment maps not loading into renderer.. help please
    renderpluginsextensions
    4 Posts 2 Posters 743 Views 2 Watching
      monkers
      Hi Guys, Kinda need some urgent help here!
      My SU+vray projects are few and far between so I get a little rusty in between but im sure im not missing something here.
      I cant Figure out for the life of me why Vray wont send the environment maps to the renderer. I can see it loads all other maps just fine.
      I have tried a bunch of different maps and in different locations. Its not like its even trying to load them theres no errors about the file not being found.
      Please help πŸ˜•
      SU 15.3.331 x64
      Vray 20025244
      • kimi kimiK Offline
        kimi kimi
        Can you post some more specific information? But my blind guess is that you didn't adjust your multiplier value and everything is black.
          monkers
          Thanks Kimi,
          Which details would you like?
          I have checked that, same settings as I have used in the past (older versions of SU/Vray) my concern is I cant see the maps getting loaded into the scene in the Vray progress window...
          I Just want it to reflect on the windows. My Skyscraper is going to look strange without it. If theres a work around anyone can suggest to bypass the environments - I have a feeling it a bug of some sort.
          Thanks!
            monkers
            a simple PC restart seems to fix the problem. Strange the map still doesn't load in the progress window but its working now.
