    Sketchup Export to DWG not working
    4 Posts 2 Posters 4.7k Views 2 Watching
    • B
      bluegravy
      I am trying to export a model as a 3D DWG file. The skip was originally created using Sketchup Pro 2008. I have saved it again using Sketchup Pro 2015 and tried to export. A dialogue box appears which says 'exporting 3D model' then closes. I have checked the target directory and there is nothing there.
      • TIGT
        What are the Options you have set in the Export dialog ?
        Are you saving into a folder that you have permission to write to ?
        Have you tried a simple box SKP Export to see if it's something with your particular model ?
        Have you tried Model Info > Statistics > Purge Unused AND Fix Issues options, in case there's something awry ??
        • B
          bluegravy
          Set all options on.
          Yes I have permission to write to the target folder.
          The simple box skp export worked fine.
          Tried the 'Purge Unused' and 'Fix Issues' options.
          Still no joy.
          • B
            bluegravy
            Have since tried switching all options off then one option at a time.
            Still no joy.
