    Importing vismat into sketchup issue
    renderpluginsextensions
    6 Posts 4 Posters 3.7k Views 4 Watching
    • R
      rookie2009
      Hi Folks
      I started using Sketchup for the first time this week so I'm a bit of a novice so bare with me πŸ˜„
      I'm creating a new material in my model,for examples sake we will call it windowframes...so I create that through the SU material editor.. Now I want to apply my wooden vismat material to it,so I open the vray material editor,find windowframes and import my texture..
      Now the issue I have is when I click import or apply my vismat to windowframes,instead of the material texture been shown,the object I'm applying the vismat to just reverts to the standard dark grey/blue colour which SU uses by default... If I render the material will show there,but not as I'm working in the current scene,its just the default SU colour..
      Can anyone help me out,advice much appreciated πŸ˜„
      • V
        valerostudio
        Sounds like you changed your Viewport viewing style in SketchUp to show Monochrome mode. Just change the viewing style to Texture mode.
        • R
          rookie2009
          Thank you for your reply Valerostudio..It doesn't seem to be that as I had ''shaded with textures'' selected..I cant for the life of me figure it out lol,Ive just installed it a couple of days ago so most settings are default..
          For example if I apply a brick finish to a wall from the Sketchup paint bucket it will appear with no issues in the current scene..however if I proceed to open my Vray Material Editor,go to my brick material which I have used,then click import material and open my vismat brick material..as soon as I click open,in the scene the brick finish will disappear from the wall I was working and and it reverts to the default Sketchup material colour/dark grey colour for some reason instead of being updated with the vismat material...
          • R
            rspierenburg
            When you import a Vray material it automatically will add the Diffuse layer to SU's material Palette. So just import your Wood vray material and then use SU to paint it on your windowframes.
            • R
              rookie2009
              Thanks guys all sorted now..Hopefully I wont have to come back with too many more questions πŸ˜›
              • S
                starlord
                How did you do it? I've got the same issues like yours.
