    Can anyone Help me in sketchup 8?
    4 Posts 2 Posters 502 Views 2 Watching
    • T
      T69xRiPx
      even my su version is out dated, i dont know if this should posted and i dont know if this topic is posted in sketchucation before but i need help with my problem. If this topic shouldnt be here please someone move it to the right thread
      My problem is that my ruby console is spamming a message like.....
      Menu_text: component attribute
      Tooltip: component attribute
      .....many time and some times i just cant right click, save, save as then itll usually go to bugsplat, i dont know what to do, please help
      • TIGT
        You seem to have a Plugin loading which prints some messages to the Ruby Console.
        It always do that, but it may be faulty ?
        The splats might be unrelated...
        Use the SketchUcation PluginStore Toolkit's Plugins-Manager to Disable all of your Plugins, enable some and restart SketchUp - this will allow you to see which Plugin is doing this...
        You can use Sets...
        If you have recently added some Plugins and the problems then started, you can speed up the process by concentrating on testing those Plugins first...
        Once you have a group that you know to cause it disable 50% and restart... if the message stops then the culprit is in the recently Disabled ones...
        If you have many Plugins loading which are rarely used then you might consider Disabling those anyways and temporarily Enabling them [Orange button] when you need them...
        Having any Plugins loading slows SketchUp's start, and is an unnecessary set up...
        • T
          T69xRiPx
          Thank you for the answer sir, and i have downloaded the Sketchucation plugin toolkit - and i dont know how to use "sets"....
          i have tried to uninstall plugins in sketchup using the sketchucation toolkit but the plugins is still there whenever i restart it
          thank you again in your reply
          • TIGT
            If you have v8 you need to be sure you have permission to modify the Plugins folder - without that changes made with the Plugins Manager will NOT be retained on a restart of SketchUp - see this...
            http://sketchucation.com/resources/tutorials/intermediate/811-setting-security-permissions-in-sketchup
            Also see this on generally installing Plugins...
            http://sketchucation.com/resources/tutorials/beginner/108-installing-sketchup-plugins
            and this on the PluginStore tools...
            http://sketchucation.com/resources/plugin-store-download
            which has sections on the Plugins Manager - you are NOT Uninstalling them - you are Disabling them.
