    Join Pipes Smoothly?
    27 Posts 10 Posters 2.4k Views 10 Watching
    • KrisidiousK Offline
      Krisidious
      I have this roll bar that was made in a low poly format. I would like to replace it with higher poly model that joins at the junctions nicely. Anyone know of a plugin that would help?
      By: Kristoff Rand
      • ntxdaveN Offline
        ntxdave
        [attachment=0:2p3ui7eh]<!-- ia0 -->rollbar.JPG<!-- ia0 -->[/attachment:2p3ui7eh]
        Have you looked at something like Profile Builder 2 or tried using the Solid Tools > Intersect to combine them.
        Press F1...thank me later
          Krisidious
          I have profile builder pro version 1? and it only works on lines I think and as for solid tools I tried but didn't work.
          By: Kristoff Rand
          • Bob JamesB Offline
            Bob James
            Profile Builder Pro Version 2 is very much more powerful at doing what you need.
              Krisidious
              Hmmm...
              By: Kristoff Rand
                driven
                are they 6 sided polygons or circle?
                can you post that model?
                you may be able to rebuilding from those using code or manually...
                john
                • ntxdaveN Offline
                  ntxdave
                  Yes, I was able to go in and manually start combining things but it takes a lot of work and I did not do the whole thing. Because of the shape of the bars and overlapping them, you have to erase some edges and it takes time.
                  Still sees like the idea would be to draw a series of lines in the configuration you want and then use the Profile Builder 1 Pro that you have to create the whole thing in one shot.
                  • BoxB Offline
                    Maybe I'm missing something, but isn't it a few minutes work with follow me?
                    Edit: Just noticed your comment about it being about whole cars not just this one job, so ignore me.
                      Krisidious
                      Yes, the line and follow me with profile builder is how this was built, but that's not the goal, to be able to build it. It's to be able to convert it in to a connected shape when it's not currently.
                      These are low poly existing models. They need to be converted to higher poly models.
                      Now, if you could make a plugin that found the centers of each bar... that would be just as good if not better.
                      By: Kristoff Rand
                        Krisidious
                        Yeah, I know I can do it manually... I was wanting to attack the problem, as it is common in converting low poly cars to high poly.
                        here ya go... don't waste too much time on it. It's not a job or anything.
                        rollbar.skp
                        By: Kristoff Rand
                          Not sure I understand the center of what? πŸ˜„
                          Refound the center of an arc circle or circle ? This exists by Chris Fullmer
                          (the inverse draw a perpendicular circle by the extremity of a segment ? This exists by Chris Fullmer )
                          the center of gravity of something? This exists by TIG
                            Krisidious
                            Center of the pipes by building a line that could then be used to rebuild the pipe.
                            thanks for Perpendicular Face Tools though. gonna need that.
                            By: Kristoff Rand
                              If you're talking about whole car bodies, what about using Artisan?
                                Krisidious
                                The bodies I can bring straight over and or easily rebuilt their topography. The roll bars are in the right place, but need to be rebuilt.
                                By: Kristoff Rand
                                • BoxB Offline
                                  Kris it's all geometry, edges and faces, I think you need to be more specific and tell us exactly what you need to do. To me sorting the car shell would be important and a roll cage something that I could fix in seconds. But is seems the other way for you.
                                    Krisidious
                                    I thought I had been pretty specific. I need to recreate roll bars with connect geometry. from the simplistic and disconnected ones I have or get.
                                    By: Kristoff Rand
                                      Tubes which are linear - like the horizontal parts - can be easily extruded as tubes - that is if those path edges are welded into one continuous curve - perhaps with a transitional arc joining the straight bits.
                                      Like my PipeAlongPath...
                                      If you have an L junction a welded path will also extrude as you hope.
                                      Add a transitional arc at the elbow if you don't want a right-angle mitered bend.
                                      When you have a 'T' of a tube meeting another tube at something like a right-angle, then make the two parts, then use Fredo's RoundCorner tool to make a proper 'filleted' joint - i.e. just like you'd get with a real-world 'weld'...
                                      If the scale of the modeling doesn't warrant such detail, then simply 'intersect' the two parts and delete the unwanted geometry...
                                      You'll need to do some exploding/combining of geometry if parts gets grouped as you make them...
                                      • andybotA Offline
                                        andybot
                                        Just thinking - you could use vertex tools to merge close vertices. That may work to clean up the breaks at each bend in one shot.
                                        Edit: looked at the model - that works only for the smaller bends. For the perpendicular intersections, not much help there.
                                        rollbar2.skp
                                          Krisidious
                                          That sounds like the labor I had envisioned Tig. I was really hoping for a clickable cure.
                                          Andybot, that did work, but each vert had to be welding 1 at a time. again pretty time consuming.
                                          And all of these work-arounds seem like more work that just rebuilding the roll bars.
                                          I guess that will have to do.
                                          Thanks for all the suggestions.
                                          By: Kristoff Rand
                                            There's no such thing as a free-lunch !
                                            • 1 / 2
