    Simple mirroring
    10 Posts 5 Posters 727 Views 5 Watching
    • jojo9J Offline
      jojo9
      since my start with SU6, i used thoroughly the: mirror on red/green/blue axis feature in the context menu.
      Sometimes i tried plugins in the hope to get that basic feature in a toolbar plugin version, but in vane. I saw several interesting align tools, usable, but not necessarily one-click commands.
      Isn't there a mirror ruby maybe with toolbar, offering the same basic mirror-functions as i search?
      If there isnt, im able to cobble together a toolbar myself, but id need the commands doing the mirroring. Thanks for any help!
        Mirror by TIG ?
        http://sketchucation.com/forums/viewtopic.php?t=31410#p276512
        • jojo9J Offline
          jojo9
          TIG is a great coder, but this plugin is again a kind of align-tool. The mirror options of the context menu are faster and simpler
          • TIGT Online
            A basic search in the SCF PluginStore for 'mirror' returns this !
            http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=mirror%26amp;submit=%3F
            http://sketchucation.com/pluginstore?pln=Mirror
            How much easier could we make it ?
            It is NOT an 'align tool'...
            There are several of those around too...
            It mirrors the selection about a point, line or plane.
            The usual usage is about a plane, which is defined by three picked points.
            You then have the choice of keeping the copy or mirroring the original...
            It can never be a 'one-click command' because you need to communicate to SketchUp the nature of your mirroring desires - about a point, a line or a plane 😒
            How is Sketchup going to know how you want the 'flip' to be oriented.
            The context-menu does them axially - so it's almost one-click [if that's all you need use that!], but to mirror freely about some arbitrary picked point/line/plane needs a little more input from you - the users...
            • pbacotP Offline
              You want the "flip" commands to be provided in icon format? Maybe another approach is to set a key command (shortcut).
              • jojo9J Offline
                jojo9
                yes, thats a good way. In the past i used tons of keyboard shortcuts, but nowadays i prefer toolbars. Nevertheless, thanks!
                • jojo9J Offline
                  jojo9
                  Thanks, but you need not to explain what your plugin does, its obvious. Its perfect for those who want more control over the mirroring action. Btw, wasnt my intention to reduce your work, you made a great script.
                  Since im a huge fan of toolbar buttons, id enjoy to have those simple mirror commands shipped with su only, but as three scripts.
                  • jojo9J Offline
                    jojo9
                    somebody so generous to share how to mirror objects, like with the common flip along red/green/blue axis shipped with Su?
                    shortcuts are a good way, as Driven correctly pointed out, but sometimes i get a beep with these commands mapped on shortcut key. 😕
                    i searched alredy for snippets on the Su Ruby api documentation, but cant find one …
                    • HornOxxH Offline
                      HornOxx
                      Hi Jojo9
                      using shortcuts also was my choice in the same matter.
                      I wanted to use "Alt + x", "Alt + y" and "Alt + z" because I was
                      used to these shortcuts by another software I use.
                      Forum member Cotty gave me this little help to do so:
                      http://sketchucation.com/forums/viewtopic.php?f=10%26amp;t=60763
                      never trust a skinny cook
                      • jojo9J Offline
                        jojo9
                        confusing if su works that way- 😮
                        i will look into it. Dankschön.
