    Geometry size not consistent in SU 2015
    32 Posts 10 Posters 1.2k Views 10 Watching
    • pbacotP Offline
      So if your object is not orthogonal it cannot have accurate dimensions? Really?
      • cottyC Offline
        cotty
        No, if the geomtery is accurate, the dimensions will be too.
        my SketchUp gallery
        • Wo3DanW Offline
          Wo3Dan
          That is not what I am saying.
          But working with some geometry that is slightly off means that you should be extra cautious when expecting to continue collinear or coplanar. The axes may draw new edges on axis
          Of course it is possible to model 'not orthogonal'.
          Also with geometry slightly off axis the 'Dimensiion' tool may indicate the ortoganal dimensions instead of the expected real edge lengths. Here again you can of course get the real edge lengths but SketchUp may trick you without bein noticed.
          Thing is that the original model wasn't accurate anymore, maybe due to moving some edges or faces.
          • dereiD Offline
            derei
            But is interesting how the geometry ended slightly off-axis when all of it was drawn using axis inference.
            This was actually my problem... i know how to measure/check things... but I am still confused how can be possible that drawing parallel to axis can result in displaced geometry. And whats even stranger is that turning on ColorByAxis, all edges seemed aligned.
            DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
            • ely862meE Offline
              ely862me
              Don't be bothered by that, Sketchup has its limits. Just be aware of them. The more you get into it the more you will be surprised(in worse)-especially when working with that much precision and small objects.
              PS Make the habit of purging your model. There are plenty of components in the model that perhaps you don't want to share with everybody.
              Elisei (sketchupper)
              Come and See EliseiDesign
                slbaumgartner
                A couple of thoughts:
                First, be aware that color by axis also has a built-in tolerance and will accept lines that are slightly askew. As a result, it is not useful for detecting small errors.
                Second, (it may not apply to you) on a few occasions when I let go of the mouse to enter a value via the keypad, the mouse drifted slightly off the inference point. The line, while the correct length, was slightly off orientation. This makes the dimension come out with "~".
                • S ShepherdS Offline
                  S Shepherd
                  This model has many layers and some of those layers contain geometry that is not on the default layer. I wonder if some intersect or other operation could have caused this error?
                  I've seen some odd things happen when Sketchup automatically fixes errors upon saving as well.
                  Only a thought.
                  Shep
                  • Wo3DanW Offline
                    Wo3Dan
                    @s shepherd said:
                    This model has many layers and some of those layers contain geometry that is not on the default layer. .....Shep
                    Yes, many layers, and oly two (+Layer0) remain after purging the model. I wonder what all the other geometry (in the now empty layers) was about. I guess the model was imported from some other cad program and already contained lots of little errors that you wouldn't get that easy with just SketchUp unless you use geometry from elsewhere.
                    I looked at the dwg imported floorplan and it has some thiny "off axis" errors.
                    • dereiD Offline
                      derei
                      @slbaumgartner said:
                      ...color by axis also has a built-in tolerance and will accept lines that are slightly askew.
                      @wo3dan said:
                      @s shepherd said:
                      Yes, many layers, and oly two (+Layer0) remain after purging the model..
                      Thank you slbaumgartner, I was relying on ColorByAxis until now, assuming it is precise. I won't anymore.
                      Indeed, the model was part of a bigger model (a house model with many layers). The CAD outline I imported it afterwards. It wasn't part of the drawing. All other layers had geometry on the original drawing. I just cleaned everything off, to keep the element that was trouble making. All other geometry was perfectly aligned.
                        mac1
                        derei: Nothing in the digital world is precise. SU uses floating point arithmetic and it can not represent all the real numbers. For example, the legacy 32 bit systems 8 bits are allocated for exponent and one for sign and this results in the display precision of 7 digits.( That is 24 bit since the sign bit can used). When you select display precision in SU it has nothing to do with the internal accuracy. Why display was not changed when they went to 64 bits I guess was based on lack of need; The "snap to" is over ridden by input to the measurement box, but using is not helpful IMHO=> deselect and watch for the end point or intersection or other inference engine indications. Allowing a program to make unilateral correction without user control I do not do unless initiated by myself. Beore anyone comments I am aware error detection/correction is used every where 😄
                          mac1
                          derie: Think you need to take a look at this step in the model:
                          <..... attached the original file - with the original axis orientation. Is part of a house that has a specific orientation, based on some topographic measurements and terrain.>
                          The model is " racked " some way + checking the evelation position shows confirmation of what Dave reported. I even confirmed there is no extraneous geometry causing the " problem". How and why that happened I have no idea but is high probability it is caused by OP. ( aka you). Before you proceed very far with model correcting now is a good idea??
                          FYI ref my post above: The 64 bits results in a almost 16 decimal digit precision ( 53 log (2) = 15.955 vs 7 one gets with 32 bits.
                            mac1
                            Derie: FYI The attached pic shows both the orginal on left and your problem model on right. Each is locked in my skp. You posted model was flattened, then used PP to extrude up to height shown in original and dimension shown at same display resolution for each. As can be seen both correlate. This approach basically replicates your model and one would expect both to be same. However, if the contention SU randomly changed model it seems reasonable errors in x,y which is not case. Detail look at steps in model creation can hopefully find where error was introduced.
                            • 2 / 2
