    Correctly mapping a curved surface
    7 Posts 5 Posters 710 Views 5 Watching
    • omiKronO Offline
      omiKron
      I'm trying to map correctly a building section that is curved and two angles inclined vertically and a sliced top to another angle - as seen in the cad screenshots - without success. I've tried SketchUV, UV Toolkit and Roadkill but with no result.
      Does anyone have an idea on how to correctly achieve this?
      The main point is that the panels need to have the same width on the top section of the curved corner and it's thin on the lower side as the curved corner gets smaller - top edge of glazing -
      Side Elevation
      Front Elevation
      Textured
      Visible lines
      • cottyC Offline
        cotty
        Can you share the face and a sample texture?
        my SketchUp gallery
        • cottyC Offline
          cotty
          Have you tried ThruPaint too?
          A quick try with 3d panels and flowify...
          front_flowify.zip
          my SketchUp gallery
          • ntxdaveN Offline
            ntxdave
            Shape Bender might also be an option.
            Press F1...thank me later
            • panixiaP Offline
              panixia
              @juju said:
              You could give Handbrake (now free) a spin, however I think the main application for it is a little different to what you have in mind.
              isn't "handbrake" a free mp4 converter? maybe you are messing it with "roadkill"? 😲
              • jujuJ Offline
                juju
                hmm, looks like I was in too much of a hurry, well spotted.
                the software I was referring to is in fact handplane
                http://www.handplane3d.com/
                • jujuJ Offline
                  juju
                  You could give Handbrake handplane (now free) a spin, however I think the main application for it is a little different to what you have in mind.
                  EDIT
                  thanks for pointing out the error
