    Reflection without texture
    renderpluginsextensions
    4 Posts 2 Posters 549 Views 2 Watching
    • H Offline
      horsinho
      Hi everyone. I’m having a problem rendering reflections, sometimes instead of reflecting the texture I’m using, there’s a white area in its place. I’ll put an example below. As you cam see on the left of the image, instead of reflecting the wood texture, it shows a white area.
      I’m not sure if it’s a bug, or just a basic mistake I’m making somewhere.
      If it’s a bug, I’m still using Vray 1.49, hopefully by the end of the year I can jump to 2.0, but it’d be nice to have a workaround for this in the meantime.
      I’d appreciate if someone can say if this is supposed to occur.
      Thanks in advance for all suggestions.
      • omiKronO Offline
        omiKron
        Reversed faces give glitches inside renderings. Especially on gloss/semi-gloss surfaces. Reverse from blue to normal then try again.
        • H Offline
          horsinho
          That solved it indeed, Thank you very much. First time I had this problem, from now on I'll be aware of this. Thanks again.
          • omiKronO Offline
            omiKron
            Glad it worked! 👍
