    Sketchup class load method
    2 Posts 2 Posters 2.6k Views 2 Watching
    • ChiefwoodworkerC
      Chiefwoodworker
      Hi guys,
      I believe there may be a bug (or incorrect implementation) with the Sketchup class load method. My understanding of the Sketchup class load method is that it is modeled after the Ruby Kernel load method but designed to handle scrambled files (.rbs) as well as non-scrambled files (.rb). The problem is that it doesn't seem to behave the same in that the Kernel.load method will load a .rb file even if it is already loaded - with the appropriate warnings - wereas the Sketchup.load method does not; even when executed from the Ruby console.
      For example:
      Kernel.load 'cabwriter_factory_settings.rb' results in
      C:/Users/Joe/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/cabwriter_factory_settings.rb:17: warning: already initialized constant CabWriterFactoryInitialize::NEW_PROJECT
      C:/Users/Joe/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/cabwriter_factory_settings.rb:17: warning: previous definition of NEW_PROJECT was here
      true
      Whereas Sketchup.load 'cabwriter_factory_settings' results in
      false
      Am I missing something or is this a bug?
      Joe....
      http://www.srww.com
      • TIGT
        load "some_text_file_in_the_load_path"
        always returns true unless there is an error.
        require "some_text_file_in_the_load_path"
        only returns true if that file has never been loaded before during that session.
        Sketchup's own require and load are designed to work with text files [typically RB files] OR its specialized compiled RBS files,
        Oddly Sketchup::load is actually an alias of Sketchup::require - so both of them will return false if the file has been loaded before.
        So when testing use ' load' instead !
        Compile the RB to RBS if desired and use Sketchup's method to load it - only when you've debugged the code...
