    Dynamic Beams
    5 Posts 5 Posters 2.1k Views 5 Watching
    • E
      excygnet
      Does anyone know if someone has already created a Dynamic Component for standard structural steelwork I beams?
      Note: I am interested in other standard member shapes (e.g. hollow boxes and tubes, channels) but I beams would be the main one I would use.
      Kind Regards
      • D
        driven
        have you looked at Engineering Toolbox or 3skeng?
        • R
          rodman100
          I've been looking for something similar for a while, mainly to simplify the drawing of steel portal frame structures and I'm fairly certain that nobody has come up with a specific dynamic component or plugin to help. 1001bit Tools (author Goh Chun Hee)is a great plugin and well worth a look. It's available from the SketchUcation Plugin Store.
          • JQLJ
            JQL
            Whaat's - Profile Builder 2
            Tak2Hata - Structure Tools
            www.casca.pt
            Visit us on facebook!
            • oceanembersO
              oceanembers
              Assuming you aren't looking for joints etc., it's a pretty simple dynamic to make. You'd probably do better with some of the plugins mentioned above, but here, I attached one for you. Pretty basic - use the options to change height, width, flange/web thickness. Scale tool changes the length.
              I-Beam_DYN.skp
