Dynamic Beams
Scheduled Pinned Locked Moved Dynamic Components
5 Posts 5 Posters 1.7k Views
  • E Offline
    excygnet
    Does anyone know if someone has already created a Dynamic Component for standard structural steelwork I beams?
    Note: I am interested in other standard member shapes (e.g. hollow boxes and tubes, channels) but I beams would be the main one I would use.
    Kind Regards
      driven
      have you looked at Engineering Toolbox or 3skeng?
        rodman100
        I've been looking for something similar for a while, mainly to simplify the drawing of steel portal frame structures and I'm fairly certain that nobody has come up with a specific dynamic component or plugin to help. 1001bit Tools (author Goh Chun Hee)is a great plugin and well worth a look. It's available from the SketchUcation Plugin Store.
          JQL
          Whaat's - Profile Builder 2
          Tak2Hata - Structure Tools
          www.casca.pt
          Visit us on facebook!
          • O Offline
            oceanembers
            Assuming you aren't looking for joints etc., it's a pretty simple dynamic to make. You'd probably do better with some of the plugins mentioned above, but here, I attached one for you. Pretty basic - use the options to change height, width, flange/web thickness. Scale tool changes the length.
            I-Beam_DYN.skp
