    Inserting windows
    3 Posts 3 Posters 385 Views 3 Watching
    • G
      garystan
      Hi everybody :
               I'm searching for a tutorial on how to insert windows/doors on either a single or double faced wall.
                                          Thanks,
                                        garystan
      • cottyC
        cotty
        One example for double faced wall and components:
        http://sketchucation.com/resources/tutorials/intermediate/321-window-cut-hole-thick-wall
        my SketchUp gallery
        • TIGT
          If you make your window component with gluing/cutting behaviors, and its blue axis matches the wall face's normal [automatic if component is made on a face initially], then it'll 'cut' a hole in the face onto which you initially place an instance of it [at least if it's in the same 'context']
          My "HolePunchTool" lets you punch a real hole in a multi-skinned wall, and then that 'hole' selects/moves with the associated cutting component.
          http://sketchucation.com/pluginstore?pln=HolePunchTool
