    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    How to Import Sketchup model into CNC machine
    extensions
    4 Posts 3 Posters 2.1k Views 3 Watching
      rnpatel9789
      If I have Sketchup model (for eg: one Carcus) and I want it to import into the CNC Wooding machine but it doesn't support '.skp' format. Is there any solution that I can import it into the CNC machine or I can change it into the Machine compatible format(for eg: .dxf).
        Plugin Import Export STL by Didier Bur will be maybe more suitable ? โ˜€
          Didier's is at http://sketchucation.com/pluginstore?pln=stl_import_export [suitable for <=v2013 only - it is 10 years old!]
          There is a better/newer STL importer/exporter from Trimble - in the Extensions-Warehouse...
          https://extensions.sketchup.com/en/content/sketchup-stl
          Most CNC machines will accept a 3d DXF - so with Pro do the export with the supplied exporter [best option], or with Make get a free DXF exporter plugin -
          http://sketchucation.com/pluginstore?pln=dxf_export - although it's a bit old and limited ?
          Also http://sketchucation.com/pluginstore?pln=Fishelzon_GcodeTools is also a CNC G4 exporter, but I suspect it's old and maybe no longer supported/working ?
            You can also use FormZFree who has import SKP then export from it in STL! ๐Ÿ˜‰
