    Vray load error
    renderpluginsextensions
    5 Posts 3 Posters 5.8k Views 3 Watching
    • ShyamscoolS Offline
      Shyamscool
      Hello everyone,
      So I just found out about the A2 extension toolbar thing and installed it. It installed fine but started getting this error:
      %(#FF0000)[Error Loading File vfs.rb
      Error: #<NameError: uninitialized constant WinFunc>
      C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb:97:in ensure in <top (required)>' C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb:97:in <top (required)>']
      I tried thomthom's suggestion of changing vfs.rb to
      %(#0040FF)[puts "vfs.rb loaded"
      require 'sketchup.rb'
      require 'extensions.rb'
      if( not file_loaded?("vfs.rb") )]
      That did not help unfortunately
      Is this some bug? Should i ge in touch with vray support about this? or just remove A2 Toolbar?
        Shyamscool
        Yelp!
        • pyrolunaP Offline
          pyroluna
          You may have installed the 32 bit version where you needed to install the 64 bit version or vice versa.
            Shyamscool
            you mean I might have not installed 64 bit vray? or is there a 64 bit A2 toolbar? I couldnt find anything like that.
            I am sure I have installed 64 bit vray
            • TedVitale_CGT Offline
              TedVitale_CG
              You might want to log into http://www.chaosgroup.com/en/2/downloads.html and just download the 64bit and reinstall to be sure. The installer should read as follows: vray_adv_20025539_sketchup_2015_win_x64
              Ted Vitale
              Owner | Creative Director
              http://www.voxl.vision
