    [Plugin] FredoTools::SolidVolume - v1.4a - 10 Feb 20
    25 Posts 8 Posters 16.4k Views 8 Watching
    • fredo6F Offline
      fredo6
      http://forums.sketchucation.com/download/file.php?id=49290
      SolidVolume is a standalone script which is part of FredoTools.
      It computes the volume and the total faces area of the true solids (groups and component instances) in the selection.
      SolidVolume gives the correct value regardless of the orientation of faces and the position in the model.
      It is now based on a persistent web dialog box, allowing you to change the selection or use the outliner.
      This follows an interesting discussion in this thread.
      Select the solids and invoke SolidVolume
      • in the contextual menu FredoTools > SolidVolume
      • in the menu Tools > FredoTools > SolidVolume
      • by clicking on the icon of SolidVolume (barrel)
      In this second version, the volume and faces area is displayed in a persistent dialog box. As long as it is open, any change of selection will show the volume and area dynamically. You can choose your preferred units and number of decimals.
      http://forums.sketchucation.com/download/file.php?id=49287
      SolidVolume is installed as part of FredoTools 3.2c and above.
      See the main post for this plugin for Installation of FredoTools
      http://forums.sketchucation.com/download/file.php?id=49286
      no documentation yet
      • SU Versions: SU2017 and above
      • Platforms: Windows and Mac
      • Languages: English
      • Menus: by default, SolidVolume is installed in Tools > FredoTools. There is also an entry in the Contextual menu.
      • Icon toolbar: Fredo6 Tools. There is only a single icon. By default, it is not shown. You need to go to the Default Parameters… dialog of FredoTools to enable the icon.
      • The plugin is free, for private and commercial usage.
      http://forums.sketchucation.com/download/file.php?id=49284
      http://forums.sketchucation.com/download/file.php?id=49288
      Just launch SolidVolume on a selection containing solids to compute their aggregate volume and the total area of their faces.
      The dialog box is persistent so that you can change the selection, manually or via the outliner.
      http://forums.sketchucation.com/download/file.php?id=49289
      SolidVolume 1.2b – 12 Mar 18: Fix a bug in the calculation of volume (for certain solids where the center is outside the solid)
      SolidVolume 1.2a – 09 Jul 15: Solid with holes are considered Solid and you can calculate its volume. Area of faces takes the holes into account
      SolidVolume 1.1d – 29 Apr 15: fixes bug for the height of the dialog box
      SolidVolume 1.1c – 28 Apr 15: fixes bugs in the calculation of volumes signaled by srx and ken
      SolidVolume 1.1b – 27 Apr 15: fixes a small bug in the decimals for area
      SolidVolume 1.1a – 27 Apr 15: Second public release in FredoTools 2.7b, with web dialog box and calcuation of faces area
      SolidVolume 1.0a – 26 Apr 15: Initial public release in FredoTools 2.7a
        Cool! 😎
        And about the M2 surfaces faces?
        No possibility to add this inside this one?
        • srxS Offline
          srx
          Thank you Fredo! You are my hero! 😄 This should be incorporated in Sketchup 2016 to prevent people for making mistakes in volume calculations..In the meantime we have Fredo Sketchup.
          www.saurus.rs
          • srxS Offline
            srx
            I am sorry, but plugin has some kind of problem with the geometry you can see in the example. I didn't know the volume calculation problem was so complex.
            Example of wrong volume.skp
            www.saurus.rs
            • fredo6F Offline
              fredo6
              @srx
              That's just a bug which I will fix. As long as the shape is a true solid, there is an exact solution.
              Fredo
                And the model must be made in the rules of art! 😉
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: FredoTools::SolidVolume v1.1c - 28 Apr 15
                  SolidVolume 1.1a is a release with a few enhancements:
                  • It now computes the faces area of solids in the selection.
                  • The volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
                  • You can choose your preferred unit and number of decimals for display of values
                  See main post of this thread for more information.
                  Fredo
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: FredoTools::SolidVolume v1.1d - 29 Apr 15
                    SolidVolume 1.1d is a release fixing a problem of display of the main dialog box.
                    Fredo
                    • fredo6F Offline
                      fredo6
                      NEW RELEASE: FredoTools::SolidVolume v1.2a - 09 Jul 15
                      SolidVolume 1.2a is a minor release allowing holes for a shape to be considered as a solid. The Volume is computed as if there was no hole, but the area of faces takes the holes into account.
                      Fredo
                        Alex37550
                        Hi Fredo
                        I was so happy to find this plug in volumes, but it seems there is a problem with the volumes. i had a complex solid an found a volume that seemed very big. So i try with a small cube with an hole (20 cm for each side) and there is definitively a bug. see image
                        I downloaded the latest versions of LibFredo, FredoTools (09 Jul 17) and that is the same
                        anyway, thanks a lot Fredo for all your super plugins !
                        have a good week !
                        Alexandre
                        bug solid volumes
                        • fredo6F Offline
                          fredo6
                          @alex37550 said:
                          Hi Fredo
                          You are right. There is definitely a bug and this is annoying.
                          I fixed it, and will re-release (as soon as the certification on EWH works again).
                          Fredo
                            Alex37550
                            thanks for your reactivity !
                            will you publish a reply when it will be downloadable?
                            Alex
                            • fredo6F Offline
                              fredo6
                              Alex
                              Just republish, now that EWH certification seems to work again.
                              Please advise if this fixes your problems.
                              Fredo
                                Alex37550
                                Alex
                                Fredo
                                I have not seen your post.
                                Thank you Fredo.
                                I downloaded all new versions of you plug in and solid volumes works now.
                                Alex
                                  DGR
                                  Hi Fredo6
                                  It seems that the bug in solid volume is back
                                  Regards
                                  Dirk
                                  Component_1.skp
                                  • fredo6F Offline
                                    fredo6
                                    Thanks for signaling. A major bug actually.
                                    Fixed in FredoTools 3.2c.
                                    Fredo
                                    • fredo6F Offline
                                      fredo6
                                      NEW RELEASE: FredoTools::SolidVolume v1.4a - 10 Feb 20
                                      SolidVolume 1.4a is a major release fixing issues in some situations where faces where not properly oriented.
                                      Fredo
                                        jure
                                        Hi!
                                        Calculation of volume is wrong in certain cases. See attached file.
                                        solid_volume_wrong_volume.skp
                                        • fredo6F Offline
                                          fredo6
                                          Got it and fixed it. Need some repackaging and will publish soon.
                                          By the way, the main interest of SolidVolume is that it is supposed to work on pseudo solids too, as shown in the video.
                                          • fredo6F Offline
                                            fredo6
                                            NEW RELEASE: FredoTools::SolidVolume v1.5a - 13 Nov 23
                                            SolidVolume 1.5a is a major release fixing issues in the calculation of volumes in some situations where the solid is scaled. It also adds the capability to compute the volumes of pseudo-solids: objects with multiple solids inside, objects with holes in faces or some mssing faces.
                                            Fredo
                                            1 Reply Last reply Reply Quote -1
                                            • 1 / 2
