    HDRI & infinite plane
    renderpluginsextensions
    5 Posts 3 Posters 911 Views 3 Watching
    • omiKronO Offline
      omiKron
      Hi.
      I was wondering, how can shadows on HDRI image can be acchieved using options for infinite plane? Or is there a workaround for this?
      Usually you make two renders with shadows on a white plane, then empty background [alpha], with postprocessing the final image on the shadow layout.
      Need help with this real quick! Thanks
      • omiKronO Offline
        omiKron
        Nobody?
        • JQLJ Offline
          JQL
          I could help you if it was Thea. You'd use the plan for catching the shadows and then:
          • Either assign a shadow caster material on it or;
          • Create a material for it where the background would get projected as diffuse texture. This would be made either with front or camera projection.
          Maybe there's a Vray equivalent.
          www.casca.pt
          Visit us on facebook!
            rspierenburg
            This tutorial is for VRay for Rhino, but I believe its the same idea.
            Rob
            • omiKronO Offline
              omiKron
              Thanks! I'll give it a try and see the result!
