    Round corners on inside radius of a tube
    6 Posts 6 Posters 666 Views 6 Watching
    • P Offline
      partim
      Using the round corner plugin, I can not seem to put a radius corner on the inside radius of a hole cylinder. i.e a tube with out it filling in the end.
      I can do the outside radius ok. However will not do the inside radius. I just want to remove that 90 deg sharp angle for the "hole" in the cylinder.
      Any ideas?
        Just select and delete the face skinning the hole when after Round Corner does it's thing.
        Or you could use Follow Me to round over the edge.
          driven
          one way without plugins...
          offset then alt erase...
          john
            Or use free DesignSpark Mechanical πŸ˜„
            It has SKP Import / export πŸ˜‰
            • jeff hammondJ Offline
              jeff hammond
              Any ideas?
              is there enough room left for the second fillet?
              say the pipe is 1/2" thick and you've used 3/8 for the outside fillet.. there will only be 1/8 left for the inside.
              or, attach the .skp here and someone will figure out the problem.
              dotdotdot
              • BoxB Offline
                I'm pretty sure Dave nailed it, when you round inner edges it always skins the hole and it just needs to be deleted.
