    Need help URGENTLY plz!Why can't view materials in Sketchup
    4 Posts 3 Posters 2.3k Views 3 Watching
      DewBaker
      Hi all! I'm a beginner still at sketchup but I've watched some tutorials and I'm figuring things out step by step. However, I scanned the web and still can't seem to figure out why the textures aren't showing on a model I'm working on..the face I apply a texture to will only turn to a solid color of the texture (i.e. instead of brick i get some shade of red).
      And yes, SHADED WITH TEXTURES styles view is ON, and what's driving me crazier is that I CAN view textures in all other documents I open, just not this specific one I'm working on. Problem is also apparent in print preview.
      Thanks in advance πŸ˜„
      p.s. using sketchup pro 8 on mac.
      Dew
        driven
        what is the 'scale' of the model v the 'scale' of the texture...
        if you apply a 1inch texture to a one 1 mile face, you'll only see the background color as the texture is tiny...
        Right Click a material on a face and Select 'Texture' >> 'Position' to see if it's tiny...
        john
          Check your mode...
          View > Face Style >
          If the ' Shaded With Textures' option is checked you should see textures, otherwise the other options dictate what is displayed.
          Your current Style will affect the display-mode...
            DewBaker
            john
            John you're a sweetheart! Scale was exactly the problem! Thanks a million πŸ˜„
