    Creating arcs in ruby
    5 Posts 3 Posters 536 Views 3 Watching
    • W Offline
      writestometal
      Hi Guys
      Why is the standard Arc tool so different from the add_arc method?
      I'm trying to write a script to import IDF data which defines arcs by startpoint, endpoint and include angle, to me this seems much closer to how the Arc tool works than the add_arc method (knowing that I can get the bulge distance from the include angle).
      Can I mimic the Arc tool behaviour in my script or do I have to do all the mathematics to make up the parameters for a add_arc method?
        Download my 2Dtools... http://sketchucation.com/pluginstore?pln=2Dtools
        The 2Darc tool RB includes code for making an Arc by included angle.
        You can probably borrow some ideas/code from that...
        • W Offline
          writestometal
          Wow! Didn't expect such a timely response from a guru. I'll have a look. Thanks.
          • W Offline
            writestometal
            I'm beginning to understand now. Yes I have to do the maths but applying TIG's methods make it relatively straightforward. I'm off to read more about tranformations and maybe have a look at fillets. Thanks.
            • K Offline
              killernova
              I've tried this extension, it works fine on windows, but on MacOS, when I try to draw arc with this tool, the sketchup seems to run into a dead loop(the mouse is busy, and can't do anything else except close sketchup).
              I'm using Sketchup pro 2022/2021, did you know what happened?
