    Fredo Scale question
    5 Posts 5 Posters 497 Views 5 Watching
      ania1sun
      %(#4080FF)[Hi Guys,
      I need to stretch whole to match the bowl. I use Fredo Scale. I did it before and it worked, now only length of worktop changes, not the lenght of whole, do anyone know why ?
      Anna]
      I use Fredo Scale
      I want to make the whole tighter to match the sink bowl
        Not very clear as question πŸ˜„
        an image before after and the file will fine ! πŸ˜„
        Why do you not take only the hole ?
        Tool choosen seems working as it does!
        • jeff hammondJ Offline
          jeff hammond
          you can make those type of adjustments with normal sketchup tools ..in this case, the move tool
          turn on hidden geometry and make a window selection of the parts you need to move:
          use the move tool to move it into place:
          dotdotdot
          • pbacotP Offline
            Ania1sun: You are right the tool should do this, though not necessary to use it in this operation. Sometimes nesting in the components throws it off. It appears you have it set up correctly from the picture, but no way to say why it isn't working for you.
            • fredo6F Offline
              fredo6
              @ania1sun said:
              %(#4080FF)[Hi Guys,
              Anna]
              Anna
              Make sure that your geometry does not include Sketchup curves around the plane for stretching. FredoScale does not stretch these curves.
              Fredo
