    Please repair SmartDrop
    8 Posts 5 Posters 982 Views 5 Watching
      rv1974
      Could anybody please do it so it won't conflict with Whaat's Profile Builder 2?
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=3474%26amp;hilit=smartdrop
      Thank you in advance.
        Did you try contacting the author directly?
          rv1974
          Yes I did today. Too early to say 'there's no reply' though he did not posted here for almost 2 years.
          • micioneM Offline
            micione
            Strange:
            I tried both, but they work.
            (SU 2015, windows 7)
              rv1974
              http://sketchucation.com/forums/download/file.php?id=129170&mode=view/rokbox.jpg
              more info (reply #4):
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=61283%26amp;hilit=profile+builder
              Many othets do the same issue.
                driven
                the line referred to in the error was updated by TIG for v2014...
                If you posted in the SmartDrop thread and/or PM'd TIG he may be able to oblique...
                EDIT:
                or you can comment out [i.e. add the # hashes...]
                # class Sketchup;;Group
                # 	unless Sketchup;;Group.method_defined?(;definition)
                #         def definition()
                #           if self.entities.parent.instances.include?(self)
                #             return self.entities.parent
                #           else
                #             Sketchup.active_model.definitions.each { |definition|
                #                 return definition if definition.instances.include?(self)
                #           end
                #           return nil # Should not happen.
                #         end
                #     end#if
                # end
                and see if that works... [it's already defined by SU in v2015, and it runs without that for me...]
                john
                  rv1974
                  Driven, thank you for clarification. It's OK now. πŸ‘
                  The point is the description within the ruby\forum description says its the latest v.1.4,
                  though it was updated to 1.5.
                    The PluginStore versions is v1.5x ?
                    http://sketchucation.com/pluginstore?pln=smartdrop
