    ๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Inifinite Reflexion on vray ?
    renderpluginsextensions
    6 Posts 4 Posters 5.3k Views 4 Watching
      RueM
      On my 3d model, I put a mirror opposite to one other.
      When i looked through one on them, I should have a kind inifinite reflexion.
      But my render on vray stopped after only three reflexions, as you can see in the attached file.
      What parameter should I switch ? I tried things like uncheck "maxdepth" in global switches, but nothing worked for now.
      Thx !
      3 reflexions only
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        It's a material feature, not a global feature.
        In the material editor, in the "Options" tab of your mirror material, change the "Refraction Max Depth" to a higher value.
        But you won't be able to go to infinity. Also, a value too high will probably crash Sketchup.
        • andybotA Offline
          andybot
          I had a similar case a while back. I did max reflection at 50, refraction at 16 (had those glass dividers too). Here is how it looked
            RueM
            Thank you, that worked as i wished
            • F Offline
              frankmbata
              Where your mirrors a plane or a 3D object? Because mine is a solid and itโ€™s not working ๐Ÿ˜ž
              • andybotA Offline
                andybot
                For a mirror, it's what material is applied to the surface that matters, not whether an object is a solid or a face. As far as the reflection/refraction scene settings, this was done many, many versions ago, and I don't know where the settings are currently found.
