    Measure an arc
    16 Posts 7 Posters 2.6k Views 7 Watching
    • R
      rprprp
      good night, I drew a circle with 20 cm perimeter and want to measure 2 cm how can I do it?
        You should remember your very basic geometry. If the circumference of the circle is 20, that's 20 over 360Β°. 20/2=10 and 360/10=36. So measure 36Β° of arc on your circle with the Protractor tool and you'll have an arc that is 2 cm long.
        • P
          pcmoor
          in the entity info box increase the segment to say 100 to make a smoother circle if not already so, right click the perimeter, then choose divide, enter 10
          then you will have 10 arcs that measure 2cm
          (if original circle had 100 segments, then each arch will have 10)
          • BoxB
            Aren't they normally measure in cubits!
              Only if your eyes are almond-shaped and on the side of your head. πŸ˜„
              http://www.taneter.org/Menna Surveying.jpg
              • BoxB
                Bet you can't tel me how many animals Moses took on the Ark?
                • pbacotP
                  two of each kind
                    Bet I can. You have to pour more beer into me than that to get me to trip up on that one. πŸ˜†
                    • BoxB
                      Bugga, but I got one. I'll have to send more beer.
                        πŸ˜† πŸ˜†
                        πŸ‘ πŸ‘
                        • pbacotP
                          heh....
                          • Jean LemireJ
                            Jean Lemire
                            Hi folks.
                            It is Noah that took animals on an ark.
                            Just ideas.
                            • ipsketchpiI
                              ipsketchpi
                              What if it is unknown. If I have to measure unknown arch. How to do that at SU.
                              An example how I would like it to be. But maybe there are some ways of doing that??
                              That would be a nice way. A pity its not on standard tools 😞
                              Of course, you can always count if you know arch radius and segments (all that you can see in Entity info ) or copy arch/ explode it, select all and then you will be able to see the length of exploded arch in Entity info.
                              /IP
                                There isn't a tool to make an arc dimension line. You can do that manually and add the dimension you read from Entity Info. There's no need to explode the arc.
                                • ipsketchpiI
                                  ipsketchpi
                                  but how/ where? You have to explode to see the length/ or is there another method?
                                  See images, please.
                                  not exploded arch shows radius and segments
                                  exploded/ can see length of one segment
                                  exploded/ chooses all and can see total length
                                  /IP
                                    Haven't you ever wondered what would happen if you click on that button in the upper right corner of the Entity Info window?
                                    Here's a circle, unexploded, and you can clearly see its length or circumference.
                                    It's also the circumference of the circle, not the sum of the lengths of the edge segments.
