    Measure an arc
    16 Posts 7 Posters 2.7k Views 7 Watching
    • BoxB
      Aren't they normally measure in cubits!
        Only if your eyes are almond-shaped and on the side of your head. πŸ˜„
        http://www.taneter.org/Menna Surveying.jpg
        • BoxB
          Bet you can't tel me how many animals Moses took on the Ark?
          • pbacotP
            two of each kind
              Bet I can. You have to pour more beer into me than that to get me to trip up on that one. πŸ˜†
              • BoxB
                Bugga, but I got one. I'll have to send more beer.
                  πŸ˜† πŸ˜†
                  πŸ‘ πŸ‘
                  • pbacotP
                    heh....
                    • Jean LemireJ
                      Jean Lemire
                      Hi folks.
                      It is Noah that took animals on an ark.
                      Just ideas.
                      • ipsketchpiI
                        ipsketchpi
                        What if it is unknown. If I have to measure unknown arch. How to do that at SU.
                        An example how I would like it to be. But maybe there are some ways of doing that??
                        That would be a nice way. A pity its not on standard tools 😞
                        Of course, you can always count if you know arch radius and segments (all that you can see in Entity info ) or copy arch/ explode it, select all and then you will be able to see the length of exploded arch in Entity info.
                        /IP
                          There isn't a tool to make an arc dimension line. You can do that manually and add the dimension you read from Entity Info. There's no need to explode the arc.
                          • ipsketchpiI
                            ipsketchpi
                            but how/ where? You have to explode to see the length/ or is there another method?
                            See images, please.
                            not exploded arch shows radius and segments
                            exploded/ can see length of one segment
                            exploded/ chooses all and can see total length
                            /IP
                              Haven't you ever wondered what would happen if you click on that button in the upper right corner of the Entity Info window?
                              Here's a circle, unexploded, and you can clearly see its length or circumference.
                              It's also the circumference of the circle, not the sum of the lengths of the edge segments.
