    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 227.1k Views 57 Watching
    • cottyC
      cotty
      Flowify do work in 2020...
      my SketchUp gallery
      • alvisA
        alvis
        @vizan said:
        Hello! How can I apply top geometry to bottom using your plugin?
        [attachment=0:zcrmklbm]<!-- ia0 -->img_15112019_181118.jpg<!-- ia0 -->[/attachment:zcrmklbm]
        403 Forbidden
        (sketchucation.com)
        • N
          Nan Htet Htet Aye Mon
          Hi Caul...
          Thank you so much for the amazing plug in.
          I want to use Flowify in Sketchup 2020.
          Any update for it.
          Thank you
          • cottyC
            cotty
            @nan htet htet aye mon said:
            Hi Caul...
            Any update for it.
            Thank you
            Did you read my answer to your last question?
            my SketchUp gallery
            • E
              emygarbanzo
              Hi, I have tried to use flowify a lot of times and it just doesnt work, i dont know if its because of my sketchup or something else. I have folowed every step there is so I dont know what to do.
              I would aprreciate so much if someone could help me.
              flowify 3d.skp
              • cottyC
                cotty
                You need a "Group with [only] target surface" here too...
                my SketchUp gallery
                • H
                  hrachid
                  I'm facing a problem with the extension,,,,
                  I'm using ketchup 2018,, and when i reopen the file the extension disappears !!!!
                  anyone can help?
                  • S
                    silbedia
                    I'm having an issue imposing a grid on a curved 3D surface. I have the projection plane group, target surface group, and connection edge group, all in one group. When I select the entire group and do extensions > flowify > impose grid, in order to check to see if it all works right, I dont get a grid. I adjusted the target surface so that there isnt overlapping geometry (which is barely present at the bottom of the cone) but that still didn't make a difference.
                    My target surface group uses a radial grid and not a rectangular grid in its hidden geometry, is this the problem? When I try it using a target surface with simpler rectangular geometry it works fine.
                    • J
                      Jamie1407
                      it doesnt appear and error so i guess now everything is ok. but when i click on flowify it doesnt do anything i keep waiting and nothing not even an error. Nothing.
                      thanks for your help. any help will be useful.
                      here is the file
                        @ Jamie If you want some help post your file in V6 or Maxi 2017 Make ! 😄
                        https://i.postimg.cc/FzgQ2pTb/v6.jpg
                        • N
                          nlipovac
                          On destination mesh:
                          You have two group levels inside that mesh group so I exploded that one.
                          I removed the rim around that mesh since it is not needed to wrap that Voronoi mesh.
                          Run Solid inspector and removed stay edges.
                          Removed line group and created it again.
                          On Voronoi mesh I removed thickness, you can add it after you create a new one using the JointPushPull plugin.
                          There are some weird spikes after I run Flowify but you can move them to their position manually.
                          flowifyy help.skp
                          • J
                            Jamie1407
                            Omg thank so much!
                            • J
                              junie1111
                              Hi there, can I ask one thing?
                              I tried to use plugin but I guess doesn't work when file is huge....
                              Clicked plugin and nothing happened. No alarm.....
                              Is there any method without divide geometry?
                              Any help will be helpful
                              Many thanks.
                              sketchup.skp
                              • A
                                amycreech
                                Hello!
                                I'm trying to use the Flowify extension to apply tufting to a curved sofa, but it looks like Flowify is only compatible with Sketchup 2019 and under. I was wondering if there is a similar extension I can use to do the same effect of bending the geometry?
                                Thank you in advance,
                                Amy
                                • N
                                  nlipovac
                                  @amycreech said:
                                  Hello!
                                  Amy
                                  I use Flowify for that purpose also and it works in SU 2021 just fine.
                                  Can you post pictures or a file so we can see what is the problem?
                                  • N
                                    nlipovac
                                    Many thanks.
                                    So I deleted some of your model because I do not have time to do it all.
                                    You should try and do a portion at a time to have more control and to not stall your computer.
                                    I used just the Flowify method and not Flowify without cut
                                    Here is my try on curved baluster:
                                    https://1drv.ms/u/s!AkMAr9Me_-ODgY4pxDlGCkxKzsr4nQ?e=Fc6HRZ
                                    Few notes:
                                    • You can not use components, only groups
                                    • Clean your model of unnecessary geometry, like internal geometry.
                                    • Clean your model of unnecessary lines, if you do not have any use for them.
                                    • M
                                      MalGaming
                                      Hello Caul ,
                                      Can You Update For Sketchup Pro 2020 ??
                                      • S
                                        Sir
                                        This plugin is incredible, thank you. This task put even my parametric colleagues off!
                                        OK the shingles dont stay the same size but ill take it.
                                        Thanks agian! 😮 👍 👍 👍
                                        • locoL
                                          loco
                                          What is the most recent update for Flowify? Has it been updated yet for SketchUp 2021 or 2022?
                                          Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
                                            Take somewhere a version of the free 2017 Make for use the Flowify! 😉
                                            • 6
                                            • 7
                                            • 5 / 7
