    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 227.1k Views 57 Watching
      Jamie1407
      it doesnt appear and error so i guess now everything is ok. but when i click on flowify it doesnt do anything i keep waiting and nothing not even an error. Nothing.
      thanks for your help. any help will be useful.
      here is the file
        @ Jamie If you want some help post your file in V6 or Maxi 2017 Make ! 😄
        https://i.postimg.cc/FzgQ2pTb/v6.jpg
        • N
          nlipovac
          On destination mesh:
          You have two group levels inside that mesh group so I exploded that one.
          I removed the rim around that mesh since it is not needed to wrap that Voronoi mesh.
          Run Solid inspector and removed stay edges.
          Removed line group and created it again.
          On Voronoi mesh I removed thickness, you can add it after you create a new one using the JointPushPull plugin.
          There are some weird spikes after I run Flowify but you can move them to their position manually.
          flowifyy help.skp
            Jamie1407
            Omg thank so much!
              junie1111
              Hi there, can I ask one thing?
              I tried to use plugin but I guess doesn't work when file is huge....
              Clicked plugin and nothing happened. No alarm.....
              Is there any method without divide geometry?
              Any help will be helpful
              Many thanks.
              sketchup.skp
                amycreech
                Hello!
                I'm trying to use the Flowify extension to apply tufting to a curved sofa, but it looks like Flowify is only compatible with Sketchup 2019 and under. I was wondering if there is a similar extension I can use to do the same effect of bending the geometry?
                Thank you in advance,
                Amy
                • N
                  nlipovac
                  @amycreech said:
                  Hello!
                  Amy
                  I use Flowify for that purpose also and it works in SU 2021 just fine.
                  Can you post pictures or a file so we can see what is the problem?
                  • N
                    nlipovac
                    Many thanks.
                    So I deleted some of your model because I do not have time to do it all.
                    You should try and do a portion at a time to have more control and to not stall your computer.
                    I used just the Flowify method and not Flowify without cut
                    Here is my try on curved baluster:
                    https://1drv.ms/u/s!AkMAr9Me_-ODgY4pxDlGCkxKzsr4nQ?e=Fc6HRZ
                    Few notes:
                    • You can not use components, only groups
                    • Clean your model of unnecessary geometry, like internal geometry.
                    • Clean your model of unnecessary lines, if you do not have any use for them.
                      MalGaming
                      Hello Caul ,
                      Can You Update For Sketchup Pro 2020 ??
                        Sir
                        This plugin is incredible, thank you. This task put even my parametric colleagues off!
                        OK the shingles dont stay the same size but ill take it.
                        Thanks agian! 😮 👍 👍 👍
                        • locoL
                          loco
                          What is the most recent update for Flowify? Has it been updated yet for SketchUp 2021 or 2022?
                          Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
                            Take somewhere a version of the free 2017 Make for use the Flowify! 😉
                            • locoL
                              loco
                              I see, thanks Pilou. So it hasn't been updated for these versions?
                              • jed clampitJ
                                jed clampit
                                i just cannot get my head round this, watched video after video and i don't know what i am doing wrong. i cannot even get it to impose a grid let alone wrap the object any ideas where i am going wrong ?
                                bonet cushion v2.skp
                                  I can help you only if you save your fil SKP in 2017 version or earlier!
                                  Your profile said 2013 but seems that is not updated! 😉
                                  • jed clampitJ
                                    jed clampit
                                    thank you pilou and i have update the profile
                                    i get the error message ''The extension skb is not allowed'' when i try to upload the 2017 file
                                    copy bonet cushion v2.skp
                                    • jed clampitJ
                                      jed clampit
                                      oops it worked that time once approved 👍
                                        The .skb file is a backup file which is not an allowed file type to upload. The upload worked the next time because you uploaed the actual SketchUp file which has the .skp extension.
                                        • jed clampitJ
                                          jed clampit
                                          i just got a little confused David 😕
                                            I believe that your object to project must be only one Group of elements and not a group of "groups"!
                                            So explode all and make only one simple group! 😉
                                            1 Reply Last reply 👍
                                            • 5 / 7
