    Retina display to fine to see
    4 Posts 4 Posters 436 Views 4 Watching
      tcalvin
      New Apple retina display and Sketchup Pro 2015
      The pixel size and the lines in SU are too fine to see and in some cases have trouble snapping to references.
      Is there a work around to help see the fine lines?
      • cottyC Offline
        cotty
        Did you try to search for "sketchup retina" e.g.? You'll find a lot of information about this problem...
        my SketchUp gallery
          driven
          Go to SketchUp.app in 'Finder', right click >> 'Get Info' >> tick 'Open in Low resolution' is the easiest...
          john
            slbaumgartner
            As a side note, displays with high-dpi have started emerging on Windows recently as well. We all need to keep up the pressure on Trimble to find ways to deal better with these new displays. But, I don't expect anything before SU 2016 regardless, so in the meantime we must do things like John suggests or just cope with the tiny display of items.
